Can anyone give me some ideas for the following dilemma..
The missus has just installed a 20mm Cotswold gravel patio at a depth of 50mm. Her metal chairs are now sinking into it and probably damaging the weed
membrane. The legs of the chairs are small rectangular ones. I think that they need some sort of wider load spreader added but a quick google
doesn't bring much up. The legs are solid at the base so screwing something into it is a possibility. There are 24 legs hence the locost option.
The table already has round wider feet as standard.
Can anyone point me in the right direction? Or any ideas for a home bodge job?
N1
A square of 12mm plywood say 600mm square for each chair to to sit on
Push legs through a cut hole into a tennis ball on all four legs.
Remove gravel, concrete 1" thick, spread gravel over concrete to 1" and you'll never notice sinkage.
https://camping-intl.com/products/accessories/furniture/chairs/kampa-universal-bigfoot-4pk
Or get some 3mm steel plate, holesaw 52mm rounds and drill/tap the legs, bolt in place
Thanks for the replies chaps.
Cliftyhanger.....i went for that option but square ones. Top man.
I found some 50mm x 50mm square 3mm steel packing plates for £15 delivered for 24 of them.
Gravel is the single worst patio/drive substance. Even with weed membrane you'll be weeding it throughout the year as wind-blown seeds get hold. Stuff sinks in. Gravel gets kicked about, and you need to modify you furniture to work on it. I feel for you!
