I had lots of folk asking At Stoneleigh will my seats fit the creations of Jeremy Phillips but without any firm measurements or better still a car
near me in Cornwall I'm kinda aiming into the wind a bit..
Thought about contacting the man direct but if anyone on here has a Riot, Striker or a Fury and could take as many measurements as possible it would
let me weigh up the pros and cons etc.
Mark
i know that a mk seat wont fit into a striker thats for certain
Cheers mine as they are don't either but I'm prepared to make one that does
Mark
Mines a Fury. I'll have measure tommorow (if I remember). I got my seats from e-bay but they look like the MK ones. Drivers side one only just
fits.
adrian
There are 2 R1ot's at most of the Cornish Sprints, though not at the St. Eval this weekend. However, if you need measurements in a hurry then
car No.14 (Roadgoing R1 R1ot) is at the Llandow Sprint on Saturday, I'm sure it's owner wouldn't mind you taking a tape measure to
it.
They may turn up for the next St. Eval on the 25th, you never know.
By the way, if you've got a plug for anything snug and Tillett B4 esque, then I'd love a look (Westfield)
Originally posted by motorcycle_mayhem
There are 2 R1ot's at most of the Cornish Sprints, though not at the St. Eval this weekend. However, if you need measurements in a hurry then car No.14 (Roadgoing R1 R1ot) is at the Llandow Sprint on Saturday, I'm sure it's owner wouldn't mind you taking a tape measure to it.
Originally posted by adithorp
Mines a Fury. I'll have measure tommorow (if I remember). I got my seats from e-bay but they look like the MK ones. Drivers side one only just fits.
adrian
Hello Mark
I have some dimensions for the R1ot for you.
If you Email (link @ bottom of post ) me i can send you a PDF sketch.
If you are going to make some seats i would also be interested in having some.
If you need more info just let me know.
Regards
Jason
[Edited on 9/5/08 by short track 123]
I'm desperately looking for some seats for my Striker too.
I know it's narrower than a Fury, but I'm not sure about the R1ot. I can measure the cockpit over the weekend if you still need more info!
Llandow's not exactly near Cornwall!!
If I have a chance this w/e I'll whip out the tape measure and get you some dimensions for the Striker. It's pretty small, though Intatrim Odyssey's squeeze in ok.
The Strikers seating area is very oddly shaped! The sides taper in, but the tunnel tapers out (as you can see in my avatar) and passenger and drivers
sides are different sizes.
The widths at floor height at the rear of the cockpit are:
Driver: 385mm
Passenger: 430mm
The widths at a point 600mm in front of this, at floor height are:
Driver: 320mm
Passenger: 325mm
The widths at the level of the top of the tunnel are different, since the sides of the tunnel also taper from top to bottom.
At the rear of the car the widths at the top of tunnel height are:
Drivers: 430mm
Passenger 455mm
At a point 600mm forward of this the widths are:
Drivers: 380mm
Passenger: 345mm
The rear bulkhead tilts back at roughly 20 degrees from vertical.
I hope this makes sense, if not I'll try to knock up a drawing when I get my main PC up and running (using a laptop touchpad to do CAD with is a
PITA).
Mine is a Mk2 Sylva Striker, I don't know if the Raw Striker is substantialy different or not.
[Edited on 11/5/08 by MikeRJ]
Blimey those things are small. I will measure up and see what can be done as had quite a few R1OT and Striker folk asking for seats.
Mark
Don't i know it, I think I need to lose about 2 stone before I can fit it comfortably!
