1) since the vauxhall ecotec block is the same as the c20xe, are the sumps interchangable? looking at my car with the engine in, i think the sump will
need to be shortened. could i buy a shortened sump for a c20xe and fit it right on? or will the oil pick up pipe need to be modified? or should i just
avoid speed bumps?
2) whats the best oil to have in my type 9 box?
3) as above for my full floating atlas diff? and whats the capacity of a standard atlas diff? to to give a guide as how much oil i'd need for
it
thanks guys, i know you lot know pretty much everything ever
[Edited on 24/12/08 by blakep82]
yes,i believe the sumps are interchangeable, unless the oil pickup is different. I haven't checked.
[Edited on 24/12/08 by liam.mccaffrey]
I've got a spare XE sump you can have for cost of postage if its any good to you?
Chris
Hypoid EP80 gearbox oil and EP90 final drive. The level is just below the filler hole, can't be more than 2ltr at a guess.
[Edited on 24/12/08 by Peteff]
as much as 2 litres?! i guess thats the gearbox. i think the axle will take MUCH more than that
especially at about £10 a litre....
thanks for the offer chris! I'll bear it in mind. i'll keep it standard for now. see how long it lasts
