Does anyone know if the only way to get adjustable carb needles for zx9rb1 carbs is to get a dynojet kit??
The kit is 100 quid.
I've heard of folk putting washers under them to richen things up.
I would think the needles from other CVK's would do, I've a set from a ZXR750, if the needles are adjustable you can have them to try,
I'll check tonight.
ZX6R Mikunis have adjustable needles. Not sure if they fit though.
Stu
Some have grooves, I got mine out of a set of ZZR1100 carbs. Much the same carbs apart from the tps.
You could always fit the flo-commander system
flo-commander
Has anyone here actually installed this product? comments, thgouths, opinions?
cheers
Craig
flo-commander
cheers
Craig
flo-commander
Zx9r needles are adjustable
some have clips you move up and down
model e carbs you put small washers under the head of the needle,s
i have looked in your photos but can't see which carbs you have
Jacko
Checked my spares carbs, they're fixed needles...
Which model zx9r carbs are they ?
