Trying to work our what cam shaft i have in what i beleive is a 1.9 cvh (1600 block and head).
So if these marks mean anything to anyone?
Daniel
don't know about chv but on pinto cam shafts the identification marks are on the back of the shaft
Power engineering sx428 cam
hth
Originally posted by viatron
Power engineering
Got a reply back today:
"[Its a] SX428C
Duration: 280deg
Valve lift: 0.495"/12.57mm inlet & exhaust
Timing: 34-66 inlet 66-34 exhaust
Full lift: 106deg ATDC inlet
I might be able to give you more info on the engine if you can give me the engine number"
Result, going to reply with the engine number and see if maybe i cant find out more about the other work on the engine too if it was done by them.
Daniel
Thats a massive amount of lift, and my guess is you may even need cut out's in the pistons.
That spec indicates a full on race cam....Usually not that useful unless the head has had some porting work done.....So you may well have a high spec
engine....
Do you have double valve springs, and are the tapits hydraulic or solid?....
quote:It does have double valve springs.
That spec indicates a full on race cam....Usually not that useful unless the head has had some porting work done.....So you may well have a high spec engine....
The engine is now available, if anyone is interested in it.
Unfortunately it dropped an exhaust valve, so one piston and I expect the head is a write off, however the block would likely live again as it only
has very mild damage, all other parts available.
Never did get a reply from Power Engineer!
Only after scrap value for it.
Daniel
[Edited on 12/11/2021 by dhutch]
