1.8 litre silver top zetec, 2 litre cams pair twin 40's, K+N filters, standard cast manifold ??
135-145, with more once you ditch the manifold
Standard cast exhaust manifold?? As above, 135-140bhp with your strangling exhaust system. 160bhp when you upgrade to a "proper" exhaust
take it they are 130bhp cams? im going for 140-145bhp are you going to get it on a RR to prove us right or wrong?
so you think the manifold is that restrictive ?Whats the GBS manifold like any good, as the car has been built on a budget dont want a £500 manifold on a £3k car
anything tubular and reasonably unrestrictive will be better - have you seen the inside of cast exhaust manifolds?
Would certainly be the limiting factor in your engine at the moment.
surely a good porting job on the manifold will help.
I doubt porting a cast manifold will help much, the basic design is errrr basic.
The earlier escort cast manifolds look a little bettre than the late mondy ones, and the focus tubular ones (often about £20 on fleabay) look OK too.
I just bought an ST170 manifold (probably as good as ANY aftermarket one, better than most in terms of performance) for £50. May be tricky to use in
many cars, not ideal for most locost stuff but wilkl fit my next spitfire with a little cut and shut
For ease the focus one may be good??
Don't be fooled by manifolds that are just chucked together, it take a lot of cleverness and experience to design one, something I suspect many
go-faster manufacturors lack. At least OEM stuff will have some proper research/development, albeit with cost reduction added. hence my choice of the
ST170, it was developed properly without the mass-produced cost restraints.
All IMHO of course
I would go for 125 with the cast manifold....
Not only are they very rough, but also, the primaries will be too short for good power...
cliftyhanger's idea of using an st170 manifold is probably a good one if you are pinching the pennies.
You won't get a manifold of any quality level at all for less than £300 new, and £500 for a good one. ( we certainly wouldn't entertain
making one for less than £400 )
