TAB ON DIFF SAYS?
83 bg4006kc 4 314 6j26,
HAVE READ SOME THEADS ON HERE BUT STILL IN HE DARK ! COULD ANYONE HELP!
Isn't it a 3.14 diff???
It's useless.
I'll take it off your hands fo £50
looks like a 3.14...
No wonder you are shouting!
Hi Tom, I'll swap you for a 3.62 if thats what your after...
so its is a 3.14 (good) whats the rest of the numbers mean?
Does it matter lol
You have the best bit lol
http://www.locostbuilders.co.uk/viewthread.php?tid=85080
Might give you some info
not an LSD though
not an LSD though![]()
83 BG is the prefix of all diffs in the 82 to approx. 87 model years. 4006 is the same on all seierra diffs, KC is the important bit, only the 3.14
push-in type diffs had this code, and 314 is obviously the ratio. The rest is serial No.
Double check the ratio by counting the number of propshaft rotations required for one full driveshaft rotation. If it is 3 rotations + 50 degrees
(less than a quarter of a rotation), and the diff is not welded, you can make some money... or use it in your BEC... :-)
Gergely
Take the back off and in white pen writing you'll see the magic numbers.
I bought a 3.14 but wouldn't hand over the cash until I took the back off.
3.14 tags are worth a few quid
314 swop you for a lsd........much better in the car.....lol
