megajolt
Miks15 - 5/1/10 at 01:59 PM
Right i now believe that i need megajolt to get my engine going.
What exactly will i need and where do i get it from?
I have a distributor on my engine, can this still be used in conjunction with the megajolt
My engine already has a toothed wheel and crank posistion sensor.
Any help much appreciated
blakep82 - 5/1/10 at 02:06 PM
send a u2u to paulf on here. i got mine from him
tho tbh, it should run with the distributor you already have.
what ignition system does your engine have? is it the motronic system? have you got the haynes manual?
megajolt would replace the distributor system, but with megajolt you'd also need the ford edis, coil pack, crank sensor, and timing wheel (if yours isn't already 36:1).
its probably better than the dizzy set up for a car run on non standard things like bike carbs etc, but i wouldn't say its easier to set up than what you already have
having had a quick look through the manual, it mentions the coil can be damaged by a faulty ecu. so maybe it needs the ecu to work. i thought the ignition and injection systems were seperate.
[Edited on 5/1/10 by blakep82]
Miks15 - 5/1/10 at 02:14 PM
i believe the only thing i need, mabye completly wrong, is something connected to the coil to give the AC, (what i believe old mechanical ones had were contact breakers)
Ive traced the wires back on ym BMW loom and one wire goes to the ECU leading me to believe that the ECU controlled this part on the standard BMW setup
David Jenkins - 5/1/10 at 02:27 PM
Megajolt needs the following items:
A trigger wheel on the crankshaft (some Ford cars have this function on their flywheels).
A VR sensor to read the trigger wheel
A Ford EDIS unit
A Ford coil pack
New plug leads to match
And the MJ unit, of course!
You will NOT need your old distributor or coil - although some masochists have modified a dizzy to drive the MJ, that way is a world of pain...
There is a huge amount of info on the Autosports website, all very easy to read.
BTW: it is worth it, as the system is far superior to the old dizzy, points and coil.
[Edited on 5/1/10 by David Jenkins]
twinturbo - 5/1/10 at 03:00 PM
Not sure if MJ is the same but Megasquirt can either use the coil & dizzy for the delivery of the spark or coil drivers.
I doubt it's difficult to do on MJ.
Personaly, I would go wit an EDIS4+Coilpack based setup.
In Fact, you could probably get the BMW lump to fire up with just a basic EDIS4+coil wired in. It will give a static timing but should run just about.
TT
blakep82 - 5/1/10 at 03:09 PM
^ yes, correct. don't need MJ to start with. just get running on EDIS first
Miks15 - 5/1/10 at 03:46 PM
ok mabye a dumb question...
what is EDIS?
twinturbo - 5/1/10 at 03:58 PM
Electronic Distrobuterless Ignition System
A ford ignition system introduced in the 1990's usualy consisting of an EDIS module and a coil pack.
Available as
EDIS 4
EDIS 6
EDIS 8
they do away with the distributor and instead provide one dual ended coil per pair of cylinders to operate "wasted spark"
Normaly the edis module will send a PIP signal to the ECU ( EEC-IV or EEC-V ) which will respond on the SAW line with a tailored instruction for the given engine conditions so the EDIS can control the COILs most effectivly.
If the SAW signal is lost the EDIS defaults to ( IIRC ) 10 degrees BTDC . static timing.
Hence you can run the EDIS without the ECU for testing.
Megajolt replaces the ECU ( EEC-IV/V ) in this model
TT
twinturbo - 5/1/10 at 04:01 PM
PS..
Sometimes the coilpack was replaced with COS ( Coil on stick ).
Later on they did away with the seperate EDIS modules.
TT
Miks15 - 5/1/10 at 04:08 PM
so basically i can get it running using this... and then to get it running better i can use megajolt (which will effectively replace the original ECU signal?)
So is it this what im after?
Will this get me running?
austin man - 5/1/10 at 04:16 PM
is your engine a carbed model or injected ?
Megajolt for carb, megasquirt for fuel injection
twinturbo - 5/1/10 at 04:19 PM
Yep that's a standard EDIS for kit.
You may be able to use the BMW pickup.
Else you will have to mount the ford one somehow. And perhaps if you do you can make it adjustable for the time being to get it running better on jus the EDIS.
TT
twinturbo - 5/1/10 at 04:20 PM
You will find a simple wiring diagram on google, It's fairly easy though.
TT
big_wasa - 5/1/10 at 04:55 PM
If yours is a 6 cyl bmw lump then you will need an edis 6 not the 4.
Rare here in uk more common in the usa.
big_wasa - 5/1/10 at 04:59 PM
ebay link
Be aware the edis is bugger all use with out the plug / wires. and even harder to get than the edis itself.
Miks15 - 5/1/10 at 05:11 PM
its a 4 cylinder
so the ebay link i posted is the one i want then?
Do i need a 36 tooth wheel?i think mine has a lot more teeth.
Where could i find a replacement or one i can bolt on?
twinturbo - 5/1/10 at 05:23 PM
Could be a 60-2
EBAY again for a 36-1
And then find a way to mount it...
TT
blakep82 - 5/1/10 at 05:32 PM
the ebay link will be fine, however, theres a different type of coilpack which would work better. its called 'pin in tower' i think, which if you can find a kit with that type of coil you should be able to use your existing plug leads
have you got any photos of your crank pulley? i have an idea on the trigger wheel
big_wasa - 5/1/10 at 05:44 PM
ive got a cvh front pulley with a good solid 36-1 trigger wheel on it if you want to collect before it goes in the bin ?
David Jenkins - 5/1/10 at 06:42 PM
I think people are getting confused... if you want to know how Megajolt works, take a look on this page.
The only reason for using the dizzy would be if fitting the trigger wheel was impossible. This would mean fitting a 72-2 wheel inside the dizzy, and finding a sensor small enough to read it reliably - tough to do.
Miks15 - 5/1/10 at 07:06 PM
i can get a pic of the front crank pulley tomorrow blake, why whats your idea?
Do you have any pics of the trigger wheel your offering by any chance?
twinturbo - 5/1/10 at 08:14 PM
I am not confused, just not 100% sure what modes of operation MJ supports.
A number of advanced Electronic Ignition systems still use a mechanical rotor to distribute the spark to the correct plug.
Virtual all ford Sierras with Carburettor use a version of ESC ( ESC-2 , ESC Hybrid )
In fact... You may be able to get this BMW fired on ESC-Hybrid from a 1.8 CVH.... Using the existing HT distributor. But the advance maps would be wrong.
TT
Miks15 - 5/1/10 at 09:15 PM
ive bought that edis module now...
unfortunatly off to uni again at the weekend so progress will be halted until i return at some point, so doesnt look like it will get fired for at least a month or so.
twinturbo - 5/1/10 at 09:32 PM
Take the Edis kit withyou and build the loom while you are at uni.
TT
twinturbo - 5/1/10 at 09:56 PM
infact, find a 800rpm 12v motor. Fit the trigger wheel to it. Mount the sensor and your edis kit..
Finish off building a test rig and you can impress all your mates with a spark generator....
TT
Miks15 - 5/1/10 at 10:08 PM
haha unfortunatly i dont think ill have it in time to take it to uni with me... does the loom take long to build? surely its just plugging it in to power and the sensor?
twinturbo - 5/1/10 at 10:15 PM
I think if you look at the one you have bought, it as the plugs with a lenght of wiring tails. Basical it will have been removed from a much larger engine loom from whatever car it came from.
If your not handy with electronics then wander down to the enginerring labs at your uni and have a chat with one of the electronics lecturers about the project.
TT
David Jenkins - 5/1/10 at 10:37 PM
Not necessarily talking about you!
But not MJ - I recommend reading the Autosport Labs website to get to grips with their system.
I don't see any point in complicating the way it works - the MJ supplies timing info to the EDIS unit, which in turn drives the Ford wasted spark coil - it's stunningly simple to install, set up and use. Why make life difficult?
twinturbo - 5/1/10 at 10:59 PM
Duno...
Why remove a perfectly servicabel EFI system
I would have got involved with jolt but I have no use currently, I was going to Jolt our MK1 golf to replace the rather old Lumenition Optronic ( which had already replaced the Points).. But decided to fit a Polo GT Multipoint injection engine instead.
I will be muilding a squirt or 4... I want to get all the cars bar the daily drivers onto 1 management system. Especialy my Twinturbo Sierra which currently uses the orignial piggy back controler for the extra injectors.
IS VEMS still around?
TT
