Pinto Help.. no compression on 2 cylinders.
FFTS - 13/2/10 at 02:16 PM
My mates 2.0 pinto was driving fine on the motorway then started to miss a bit and lose power gradually until the point the juddering was worse and wouldnt go above 20mph and worse with more throttle. Then stopped altogether. Webber Dgav carb spits fuel up and out the primary choke now and then if turning the engine over. Took the plugs and and found 2 wet plugs with compression and 2 dry with no compression. Am I right in guessing the timing belt may have slipped?
mookaloid - 13/2/10 at 02:17 PM
head gasket failure between 2 cylinders?
[Edited on 13/2/10 by mookaloid]
thunderace - 13/2/10 at 02:22 PM
nip up the head and see is its ok
or sniff test it.
jacko - 13/2/10 at 02:31 PM
Cam rocker ? come loose or snapped
StrikerChris - 13/2/10 at 02:36 PM
My guess too if they're adjacent cylinders?
FFTS - 13/2/10 at 02:39 PM
or sniff test it.
Sniff test???
CORRECTION!!
After turning the engine over with choke on then taking the plugs out, plugs 1 & 2 were wet and no compression, plugs 3 & 4 were bone dry and full compression.
mookaloid - 13/2/10 at 02:42 PM
ok head gasket failure between 1 & 2 pots..
FFTS - 13/2/10 at 03:21 PM
That sounds a very definate answer! Is there anything else I should check or other test before commiting to removing the head?
Any others agree or differ?
chris
mookaloid - 13/2/10 at 03:29 PM
Well it's hard to be 100% definite, but that's exactly what happened to mine with the symptoms you describe.
I guess you could take the plugs out and pour some light oil down no 1 plug hole. then turn the engine by hand a few times to see if any of the oil gets into no 2 clyinder - check with tissue paper down the plug hole.
You could check all the cam timing before taking the head off and inspect the cam shaft for damage too.
if the above are ok I'd put my 50p on it being the head gasket
good luck!
Mark
coozer - 13/2/10 at 03:45 PM
Zetec transplant??
FFTS - 13/2/10 at 03:57 PM
Originally posted by coozer
Zetec transplant??
Gasket set £13!!
Zetec transplant £????.. More
dlatch - 13/2/10 at 05:16 PM
has the head been converted to unleaded with new valve inserts?
i had a pinto head crack under one causing loss of compression
ps another vote for zetec conversion
Daddylonglegs - 13/2/10 at 06:42 PM
I'm with the headgasket gang. Sounds favourite to me.
Dusty - 13/2/10 at 08:15 PM
You could do a sort of modified leakdown test. Remove plugs. Blow air into cylinder 1 with its valves closed. Listen/feel for where it's escaping. Might hear it escaping into crankcase (holed piston, broken rings) manifolds (valve/seat damage) number 2 cylinder (head gasket failure). Or just bite the bullet and change the head gasket. After all the heads comming of anyhow!
