What accelerator cable will do for a pinto engine?
FFTS - 17/3/10 at 11:27 AM
Where for best price? does it have to be ford? specific ford?
How about this Fleabay linky
blakep82 - 17/3/10 at 11:29 AM
i guess its not the engine thats important, but the carbs you have fitted
although, one from a sierra is probably a good start
link
the one you linked might be perfect though
[Edited on 17/3/10 by blakep82]
cd.thomson - 17/3/10 at 11:31 AM
i believe most equipment uses standard solderless nipples.
I bought my bits from a bike shop: mountain bike brake cable, 2 solderless nipples and a cable adjuster for <£5 job done.
nick205 - 17/3/10 at 11:32 AM
As above, if you're using something like a Weber DGAV carb then you'll need a cable with the right plastic clip on the carb end.
Not that familiar with other carbs, but I'm guessing they'll each have a specific fitting of some kind...?
FFTS - 17/3/10 at 11:32 AM
link
Twin choke DGAV I think. Single downdraught twin weber
[Edited on 17/3/10 by FFTS]
FFTS - 17/3/10 at 11:35 AM
I like that idea.
It just the inner cable that got fooked and cut it off shorter than it can be DOH!!
cd.thomson - 17/3/10 at 11:47 AM
yes mate, definitely just get a bike brake cable if its just the inner that needs changing. They only cost pence from a bike shop or a couple of quid from halfords
Lars - 17/3/10 at 12:26 PM
+1 for bike cable
l0rd - 17/3/10 at 01:29 PM
I know i know
This one.
FFTS - 17/3/10 at 03:58 PM
Originally posted by l0rd
I know i know
This one.
Well quite practical I guess?
I mean.. it wouldn't snap would it!
FFTS - 17/3/10 at 04:04 PM
I like that idea.
Now sorted in true Locost style
Took the end cap off the outer cable cut the outer back 2", cap back on, re-attached and the job is a goodun as they say.
Thanks for the help chaps
