people who runs turbo's what type on boost control are you using?
do anyone of you use adjustable units are they worth it?
thanks
i ran an apexi on my old car worked very well indeed.
is that the one that allows differnt boost levels in each gear? is it worth having something like that, or just fitting a manual adjuster in the cockpit and turning it up when you want to
I have an apexi one on my sr20 as well and there are so many differet settings its crazy, yes different boost in different gears, 3 different fixed settings, scramble mode, and many more, just bloody expensive
Its putting out 320ish at the mo, the limiting factor on my engine is the t28 turbo
the only thing i would say is that the unit is not waterproof
Take your pic of
these
ive got one of the black ones but it didnt cost me £500
i was interesing with the old tyres, 205 wide, 2 up it would spin up in first, second and third but i changed the wheels and tyres and am now running
275 kumo v70 trackday in med compound and only get a bit of spin in first when one up.
my car is about 700kg
I've tried loads over the years. Apexi was good but very sensitive and a bit tricky to set up. Blitz and HKS was very easy to use but basic.
Some of the electronic ones are car specific though. If you want a manual one get a dawes devices, i had one in an MR2 and scooby and was highly
impressed. Once they are set up (doesn't take long) they work just as good if not better than an electric one and it gave no spikes what so
ever.
dawes devices
[Edited on 25/8/10 by Davegtst]
I think the main difference between an EBC (electronic boost controller) and an MBC (manual boost controller) is that an electronic one will give you
a lot more control over the boost levels and is changeable dependant on what gear you are in.
An MBC can serve more than adequately though but does depend on you having a good boost gauge with decent hose to it so that you can accurately see
what boost it is producing.
Should be able to pick up an EBC new from around £300 i think, an MBC is as little as £15
Originally posted by Davegtst
I've tried loads over the years. Apexi was good but very sensitive and a bit tricky to set up. Blitz and HKS was very easy to use but basic. Some of the electronic ones are car specific though. If you want a manual one get a dawes devices, i had one in an MR2 and scooby and was highly impressed. Once they are set up (doesn't take long) they work just as good if not better than an electric one and it gave no spikes what so ever.
dawes devices
I bought a Chinese boost controller like
this one and its very good - 3
years of use so far and no problems. It allows me to have 2 settings for wet and dry (and defaults to 'wet' when SWMBO borrows the car
[Edited on 25-8-10 by RazMan]
Been using a dawes style device on my GT4 for years, no problems at all. Totally removes pressure to the actuator below the crack pressure of the device, holding the wastegate tightly shut. Slight spiking possible but never saw more than 0.5psi max. I never saw the point in one you can adjust in-car personally, I have my car set up as I like it, at max boost, and live with it like that. I tuned it to be safe at that level, pushing it higher is possible but then it becomes a ticking timebomb, so why bother. Want less than max boost? Just use your right foot properly.
The primary advantage of electronic boost control is the ability to map a boost curve, to hold off the harsh spool at low rpms and create a ore linear power curve better suited to a small lightweight car. An BC simply cannot do this.
Originally posted by Strontium DogThe solenoid keeps the waste gate closed longer than a mechanical device
AVCR for me too! great pic of kit,gear base boost or rpm boost controler,had it in my car,and now got the black one fitted in my westy,highly recomended!
we use gizzmo boost controllers, on our own cars and customer cars with great success. the worlds fastest drag racing skyline has its boost controlled
via gizzmo.
feature packed
reliable
SIMPLE TO USE!!
competitively priced.
the ms-ibc is suitable for up to 3.5bar boost, has 6 fully adjustable boost memories, adjsutabel duty, gain, overboost cut, spike control, and multi
scramble options. also full closed loop/open loop boost control.
displays in kpa, bar and psi
real time boost gauge
these are £175 + vat.
GIZZMO MS-IBC HERE
also new to the gizzmo range is the ibc-R
which has the same features as the excellent ms-ibc, but also features rpm selectable duty, so you can bring the boost in smoother, or tail it off at
higher rpm etc.
£TBA
we find the gizzmos very quick and easy to install and use, aprticularly when on the dyno and we are mapping. a boost increase is a fast simple task.
unlike many other boost controllers (with instruction manuals exceeding 50+ pages!!) the gizzmo is a simple 2 button task that anyone can use and set
up!!
- colin.
[Edited on 26/8/10 by atspeed racing]
I just fit a Gizmo to my S13, not ran it to test yet but seems impressive and only hear good things about it.
Seems easy enough to set up to me and its the first controller i've used.
Just upgraded to a Life Racing F88RS ECU boost is mapped throug the range and also it runs boost in gears. Overboost button on steering wheel and launch control.
