joining exhaust
stevegough - 5/9/10 at 08:32 PM
Question for all you who have gone there + done that....
got the manifold fitted, obtained the 5" diameter silencer from CBS, which has no fittings on it.
This leaves me with 2 questions for the forum:-
How do I secure the silencer to the car?
and
How do I connect the 2" O/D manifold outlet to the 2" I/D silencer?
There is a slight upward angle on the manifold of about 5 degrees and the connecting link would also have to turn the corner of the bodywork (side panel mid-way angle).
Are the flexible connectors any good or do they restrict flow?
(sorry, that is 3 questions)!!
Awaiting lots of brilliant easy - fit suggestions....
Thanks in advance, Steve.
[Edited on 5/9/10 by stevegough]
big_wasa - 5/9/10 at 08:37 PM
tool for the job.
Andy B - 5/9/10 at 08:41 PM
I can swage a stainless connector for you and incorporate any bend angle you want, you can then clamp onto each component using micalor clamps or similar - I would just need to know both pipes OD, alternaively send me the silencer and I will tig any connection you want onto it
Give me a bell on 01449 736633 if that works for you
regards
MakeEverything - 5/9/10 at 08:55 PM
Originally posted by big_wasa
tool for the job.
Dont bother.
Ive got a set of these, and it wont expand 2" exhaust tube at all.
stevegough - 5/9/10 at 09:08 PM
Andy B you have U2U.
