Im new to the forum and i want to fit bike carbs to my 1.8 zetec engine im fitting to my escort van.
Is there any guides or how to's on the subject so i can read up on
many thanks Dan
fitting bike carbs or bike throttle bodies there is a difference in what you will need to run it and if injection it will need mapping
obviously the cheaper bike carb conversion is what im after, then progress at a later date
the engine is from a 92 xr3i 130
Bike carbs don't like to much fuel pressure, it is recommended to fit a bike fuel pump or a fuel pressure regulator such as a Malpassi filter
king.
You will need a manifold made up and don't forget the vacuum take offs for the servo.
Throttle cable linkage is usually fairly simple, just cut off the original cable end and use a screw on nipple.
Choke cable may need re routing
converting to carb is simple really have a manifold made to suit your carbs (ZX9's are okay) buy an ecu Megajolt, find an EDIS unit make a loom
and fit simples.
Or Buy my twin webbers GEMS ECU Fuel Fump, Regulator, wiring loom and Manifold all set up for a 1.8 zetec before I split and put them on ebay
price ?
£300 plus p&P set of K&N filters as well
Welcome Dan, bike carbs on a 1.8 zetec is dead easy. All you need is a set of carbs and a Megajolt.
Then manufacture an inlet to suit the carbs and your there with 165bhp.
Check my blog below as that's how I got my 7 build and through SVA.
Ignition can be found through an early Ford ecu if you have the right information.
If you need any more info give me a shout (u2u)
Regards,
u2u sent re some comments above
[Edited on 28/10/10 by alawrence]
Regards,
you should buy my megasquirt setup, will do all the megajolt will do plus it does fuel injection and comes with TB's etc. Bolt on, map it and
done, more or less!
slightly tongue in cheek. Do not assume mapping fuel injection, or indeed setting up bike carbs, is as easy as many would have you believe. Not unkown
for people to kill their engines when things go all weak and melt pistons
But it can be done, would always want to use a lamba sensor to check, or
have a session on the rollers.
Regards,
Thanks for the welcome just had a look on ebay for a megajolt kit and this is what i have found.
Complete Megajolt 3D ignition system for Zetec engines on eBay (end time 03-Nov-10 06:26:14 GMT)![]()
would that be the one i should be getting ?
Another question, what bike carbs will be best suited for my engine.
Thanks Dan.
Yup,
I've got zx9r's on a homemade manifold and megajolt on my 2.0 zetec.
As said by Coozer they are used,with great success by a few of us round here.
Zx9's are great, fuel our 2.3 duratec very well :-)
i have bought one of your inlet plates
I think ill treat myself around xmas time and buy a complete setup thats ready to fit.
So if any of you lot have what id need and are willing to sell the set up around the 26th of nov send me a msg and ill buy it
Dan
