or clutch bleeding.
My brake fluid res connects to my brake and clutch M/C. Today i've fitted the brakes/handbrake and used an easybleed kit to bleed the lines.
This worked a treat on the brake's and even showed up a few weepy connections as it gives about 20psi throughout the system.
However I can't seem to bleed the clutch at all, to the point that there's no fluid coming through to the clutch bleed point at all. Any
ideas on what it could be?
Are you sure the master cylinder is working ok and the push rod is fully out?? I'd try disconnecting the push rod fully first to make sure it is - if not then the fluid isn't going anywhere. The piston could also be stuck so try pressing the clutch in first before disconnecting
Fluid reservoir connected to brakes and clutch, is that wise?
Clutches get used more than brakes, if the seals give way you could loose brakes, nasty.
What seals? The clutch feed is about 2" above the brake feeds. If the clutch goes there's still plenty of fluid to operate the brakes
still.
I've found my problem and its a classic......... The feed for the clutch is sold and needs the end drilling out to let the fluid pass through
What a plonker!!
Originally posted by franky
I've found my problem and its a classic......... The feed for the clutch is sold and needs the end drilling out to let the fluid pass throughWhat a plonker!!
