Chaps,
Might be a simple question but the bolts holding the ancilaries onto a duratec appear to be ali as well, can you use steel bolts instead or will they
heat up differently when the engine heats up and cause a problem?
Mark.
Would be very suprised if they were ally! What makes you think they are?
They just seem soft and easy to take a corner off.
I've just been using ordinary BZP bolts
Sorry, what are BZP bolts?
Bright zinc plated steel
ta
