Well after a lot of hard work over the last week, the time came today to start my ZX12r powered Spire GTR. There was a couple of small wiring issues
but these were easily sorted - here's the vid :--
http://gallery.me.com/tkipling#100008/IMG_0419&bgcolor=black
And now to the disaster bit. My car is off the ground on axel stands, allowing us to put the car into gear and to turn the wheels gently. This
produced a weird ticking sound when the car was in gear, turning the wheels and the clutch fully retracted.
After the third gentle run trying to find the source of this ticking noise, the engine totally seized !. I must say at this point that the engine was
barely warm and had good oil pressure. The current situation is that with the gearbox in neutral, and with the clutch retracted, the starter will not
turn the motor over (stalls).
It was weird in that the noise only happened when the clutch was fully disengaged and the gears engaged. I am fairly resigned to the possibility of
taking the engine out and investigating, but does anyone have any idea's ?
Tris
When you say the starter motor stalls...
Does it turn the engine at all?
Is it not just a clutch problem that has caused it to lock up in the bell housing somehow. Perhaps that was the "ticking" noise? Can you easily seperate the engine and box to have a shufty or just crack them open a bit and see what happens?
I mean that the starter motor stalls and it's not able to turn the motor over at all.
Myke - that's what I am hoping although I would of thought that if that's the case I would be able to turn the engine over while it's
in neutral. Unfortunately it's not a straight forward job to see without taking the engine out
If the clutch won't rotate, then neither will the starter, so take the clutch cover off before you take the engine out. Chances are that the ticking noise you heard was the clutch being pushed too far by the pedal and it has probaably damaged it.
