struggle with 2nd gear on down change
nickw2000 - 18/4/11 at 07:06 PM
on the down change sometimes i struggle to f is find the 2nd gear, every other gear in good with a blip of the accelaerator
just sometimes goes in no problem to 2nd gear but sometimes struggle and cant find the gear, and end up stopped at a junction and roundabout can get in a gear!
any help please?
rusty nuts - 18/4/11 at 07:11 PM
A bit more information might be a good idea such as what gearbox? is it a BEC or a CEC?
JimSpencer - 18/4/11 at 07:13 PM
Hi
Type 9?
If so then before trying anything else, is there any significant left to right play in the gear lever when the cars in gear?
If so then replace the saddle clip (sometimes called rail clip) on the bottom of the gearlever.
Hellfire - 18/4/11 at 07:17 PM
Did you try any of the suggestions in this post?
Phil
nickw2000 - 18/4/11 at 07:21 PM
oh sorry
its a type 9 ford gearbox on a 2.0 pinto block
nickw2000 - 18/4/11 at 07:25 PM
Phil
no sorry i didnt find anything from this post
flak monkey - 18/4/11 at 07:28 PM
If everything else checks out (i.e all other gears are ok) its a common synchro problem on the T9 box. Second gear gets a lot of stick on hard acceleration.
Also what oil are you using in the box? Some oils make gear changes a pain unless the oil is nice and hot.
nickw2000 - 18/4/11 at 07:29 PM
Originally posted by JimSpencer
Hi
Type 9?
hi is this the plastic saddle? is so yes i changed this, made a difference with 3rd gear and reverse but just 2nd having the issue
nickw2000 - 18/4/11 at 07:37 PM
it gets worse as engine warms, just the standard recomended gear oil for type 9
flak monkey - 18/4/11 at 07:45 PM
75w90 GL4
Try something like Fuchs Syn 5
If its the synchro, try to double declutch, if you get it right it will go in easy.
Or do what most people do, pull harder on the lever and swear at it
