Being the clutz that I am, I have verious motors and I'm not sure what they all are....
First up, I *think* this is the original pinto starter:
26626B 12v
M79 (0.9)
G4X2A
87BB11000AA
Second, This motor is a similar size but the pinion seems to be set back 10mm, which makes sense with the reputed 10mm spacer... I think this is 4x4
sierra (possibly)
26823D 12V
M78R (1.4)
G4X2A
V90BB11000AB
And finally, the only one with any hope of fitting due to the MUCH smaller motor diameter...
0277A Motorcraft 12V
96BB - 11000 - AA
7146CA
I've tried various google searches but apart from the middle one being mentioned in a post on here, no luck. Can anyone shed any light?
The second one is the same as the lucas lrs707 I have one of each number and they are the same unit. Works fine on my zetec / mt75 combo.
One from a 2.0 dohc the other a 1.8 cvh.
Do none of them fit ?
[Edited on 29/4/11 by big_wasa]
not with the sump still holding oil!
Not sure if there are any "pattern" part motors with smaller cases, the motorcraft one is considerably smaller....
