After finally getting my newly built engine sorted i stated to put a few miles on it to run it in.
That was untill my clutch cable snapped last night
Luckily less then half a mile away from my house.
After ringing MK up today and talking to a few people im still not sure exactley what cable it was, ive been told Transit, Sierra, Cortina and
Capri.
Below is a picture I found on the internet with no part number but it is exactley the same. It measures approx 770mm from the end of each threaded end
and 870mm long cable (type 9 ball to eyelet).
If anyone can identify this cable or if anyone one has one going spare it would help alot.
This of any use?
http://cgi.ebay.co.uk/FORD-GRANADA-III-QUINTON-HAZELL-RWD-CLUTCH-CABLE-/310100503581
On hindsight it appears a little longer than yours, but may be a good place to start.
Also, The 1.6 ohc transit are quite short and have the same cable ends, but have different adjusters.
[Edited on 5/5/11 by Shandylegs]
Mine is not like in your photo i have a Capri one fitted that has a thread at one end and a plastic bobbin at the other end
thats on the outer cable
Jacko
Mine is a Capri one, but I don't know the part number. Sounds about the right length.
Stu
Burtons have a load in different lengths and quote the QH part no
I have 2 clutch cables 1 new and the one I had on the car for 2 years and 6000 miles they are the se as you're picture £12 for the new one and
you can have the old one free as a spare
[Edited on 5/5/2011 by DRC INDY 7]
Thanks for all your replies.
U2U sent to DRC Indy
Originally posted by Shandylegs
This of any use?
Hi,
I bought one the other day from Motor Parts direct. Part Number- FIR FKC1020 £11.93 including VAT
Nick
Here is one on ebay.
FORD ESCORT MK1 1.1,1.3,1.6.CLUTCH CABLE | eBay UK
Escort MK1
does this kind look any good to you ?
well if anyone else needs one thats the one dax sell for a type 9 (I beleve its a shorter version of an escort one or something similar)
