Trying to route some piping for my supercharger install...... Not a lot of room but is there a possibility of having the size of the radiator reduced
in height but making it thicker (as there is room behind) to allow for an intercooler to be installed below the rad? How much would it effect cooling
efficiency.. also, what bout not running an intercooler at all if only looking to run 6-8 psi?
New learning curve project for me.
TIA
Flaky has some nice pics on his built,
I have a 50mm core rad and a 80mm core intercooler in the nose cone of my indy check out my pics for idea's
Have a look in the sticky at the top of this section for pics of my install.
Remember that frontal area is more effective at cooling than thickness of the core. So its better to have as much area as possible and keep the core
thinner.
Thats a very impressive build! rad and cooler look fantastic.. Thanks for the inspiration and motivation
i have a rad and intercooler setup that i might have up for sale, its slightly too wide for the nose of my car, can send images for you
