Vauxhall Z20LET Engine mate to a MT75 Gearbox?
DixieTheKid - 10/9/11 at 07:35 PM
Hello chaps.
Question is as above really, a mate of mine has just purchased himself a nice vauxhall turbo lump (z20let) for a RWD project he has got going on and wants to know if it will mate to an MT75. Im not to sure if it will mate up to it, i thought you had to use a uprated type9 or T5 with a adaptor bellhousing. Is that right?
[Edited on 10/9/11 by DixieTheKid]
flibble - 10/9/11 at 07:42 PM
Any reason why it has to be an MT75 and not a Vaux Omega box as I'd imagine that must fit??
DixieTheKid - 10/9/11 at 07:47 PM
Yeah he is putting it in his P100, saves moding the tunnel i guess.
Ben_Copeland - 10/9/11 at 07:59 PM
I doubt very much if the ford bellhousing will fit in a vauxhall. He'd need a custom bellhousing and type 9/t5
ashg - 10/9/11 at 08:05 PM
gearstick on the omega box is in a very similar position to the ford boxes and its a much better box, stronger more refined quieter direct fit to the vaux engine. dunning and fairbank can make up a prop with omega flange one end and ford diff the other end.
forgot to say it fits in my transmission tunnel which was designed for a type 9
[Edited on 10/9/2011 by ashg]
DixieTheKid - 10/9/11 at 08:08 PM
Well i think he shold of done a bit more homework before purchasing the thing! Im sure he thinks he can go and by an adaptor plate you know...
big_wasa - 10/9/11 at 08:17 PM
I doubt you can by the adapter plate it would have to be custom made. They only tend to make adapters when there is nothing elts suitable.
DixieTheKid - 10/9/11 at 08:24 PM
Well put, T5 with after market bellhouseing if it was me. Mine you, what does the LET push out 200bhp? Cheap option would be the Type 9, that would cope.
ss1turbo - 10/9/11 at 09:33 PM
The Omega R25/R28 box is almost identical to the MT75 in dimensions, plus the remote linkages almost fit and the donut at the back is even the same....
DixieTheKid - 11/9/11 at 07:14 AM
Which is the better box the r25 or r28?
ss1turbo - 11/9/11 at 08:03 AM
The R28 is stronger but harder to find as it was only fitted to the 3.0 and 3.2 Omega. R25 = 250Nm torque limit; R28 has a supposed 280Nm limit but there is a bit of lee way in those figures. You also find the boxes in the Carlton and Senator, but the CIH engine has (I believe) a different bellhousing pattern so may not fit...
DixieTheKid - 11/9/11 at 02:40 PM
What did you put your box into?
[Edited on 11/9/11 by DixieTheKid]
ss1turbo - 11/9/11 at 07:11 PM
What did you your put your box into?
A Reliant Scimitar GTE...still attached to the X30XE
As I said before, I also had an MT75 box sat next to it (for a slow-progress Zetec conversion to one of my Scimitar SS1s). That has a very narrow tunnel originally taking a Type 9. The MT75 might just fit (with a little tunnel relief, I think), but without getting a 3D model or tape measure out, the MT75 and R25/8 (its the same casing) look to be almost the same box built under license (from who - Getrag?); so many similarities. I think it would be safe to say that if a tunnel can take an MT75, it can take the R25/8. Both boxes are tall though - taller than a Type 9 (in relation to the input shaft). Whereas a Type 9 can fit in the GTE bodyshell with no issues, I did have to do some "relieving" to get the R28 in but most of that was relating to the remote linkage TBH. It also hangs lower than a Type 9.
DixieTheKid - 11/9/11 at 07:49 PM
Thanks for the info bud, i've been round my mates place today. The engine is an easy fit, the MT75 is so close to mating to the LET but as you say its not quite right! Dam close though. Im Gutted, well for him anyway.
However! All this gives me a thought............ im building a Westy with a cossie lump, why dont i put a LET in mine with a omega gearbox if its that close? Ok Cosworth YB would be nice and dont get me wrong ive got 90% of what i need but i have realized the Cosworth badge comes with the Cosworth price tag. hhhhmmmmmmmmmm........ aways been a ford man myself, could this be the tipping point?!? Pocket the cash and spend else where.
ss1turbo - 11/9/11 at 08:00 PM
I don't know the little foibles associated with the conversion, but i'd go with a post-94 Saab lump as it bolts to the 'Mig gearbox due to GMs influence. Engines are rock solid (the B204/B234 anyway) and 300bhp+ costs pennies (and I mean pennies thanks to T5suite) with the 2.3. Internals are good for another 100bhp more..and some! Just keep a spare DI cartridge with you at all times as they are about the only weak point.
Know what you mean with the "Cossie Tax" - it was bad enough when trying to amass a collection of RS-only bits...
DixieTheKid - 11/9/11 at 08:33 PM
pardon me but is a T5suite and a DI cartridge?
westy turbo - 13/9/11 at 06:53 AM
I fitted a T5 to my vaux LET,and it seems that is doing good at 400hp mark,for a stock z20let the ones mentioned above will do,
but if u can afford the T5 do it once,so u dont have to worrie for future upgrades.
DixieTheKid - 13/9/11 at 10:36 AM
Where did you get the bellhousing from?
westy turbo - 13/9/11 at 10:43 AM
http://www.aframeengineering.co.uk/
ss1turbo - 13/9/11 at 12:55 PM
T5suite is free programming software for the ECU and DI = Direct Ignition; the Saab engine uses a 4-in-a-pack coil-on-plug arrangement; no distributor, no ECU (its all inbuilt) for ignition.
westy turbo - 13/9/11 at 07:23 PM
Is he happy?
