duratec engine and gearbox weight
dave r - 19/9/11 at 05:41 AM
whats one weigh as it came out of the mondeo??
engine and box together
dave
hughpinder - 19/9/11 at 07:28 AM
According to my information the duratec is 18kg less than a zetec.
I weighed my zetec complete with starter, cast iron exhaust manifold and inlet manifold, alternator, clutch, gearbox and mondeo driveshafts at 186kg, so a duratec should be 166kg. The standard starter/manifolds/alternator and especially drive shafts are all pretty heavy though. I recon you could take off at least another 10kg if you source smaller/lighter replacements.
Regards
Hugh
dave r - 19/9/11 at 03:24 PM
so if i split the engine and box it should be 2 man liftable into a van then ?
no driveshafts,
what holds them together ? normal bolts or silly torks
redeye - 19/9/11 at 03:48 PM
I managed to man handle my2.0 duratec out the boot of my car on my own but without the gearbox attached......So two people lifting the engine and gearbox should be no problem.
so long as your not build like the little guy off the old mr muscle adverts that is
big_wasa - 19/9/11 at 04:35 PM
A zetec is an easy two man lift with a bit of wood so a duratec should be a breeze
se7ensport - 20/9/11 at 07:36 PM
Fully built Duratec; enough said.
[img] Fully built duratec
Fully built duratec
[/img]
Photo curtesy of: www.turbosport.co.uk/showthread.php?127406-Grahamb-s-Mk1-Fiesta-XR2-Duratec-HE-Hillclimber/page22
[Edited on 20/9/11 by se7ensport]
westy turbo - 21/9/11 at 04:41 AM
dave r - 21/9/11 at 05:43 AM
thats quite an impressive thread where that photo came from.....
can see myself spending more time reading that tonight, after i have got the duratec out of the boot on meh own
thanks for all your answers, it got picked up by 2 of us quite easily
Fully built duratec
[/img]
