Here is a cunundrum for the collective!!
A friend of mine has an astra coupe turbo.
we have checked that it has a spark and seems to be getting fuel but won't start.
we can get it started on easy start and it runs like a bag of crud.
does easy start self detonate and therefore allow an incorrectly timed car start and run for 15mins badly?
Surly if it even runs badly then all sensors should be working?
This started after my mate decided to start track preping it.
any thoughts or advice?
When you say he has "started track preping it"
What has he done ?
Has he started fiddling with any wiring etc ?
Have you tested for a spark and to see if your getting fuel in each cylinder ?
Fuel pump priming ok ?
coil pack could be
What has he done ?
Originally posted by brookie
coil pack could be
sure it one coil pack on them
Can't be coil pack then. we have a spark.
any other takes?
if its an astra coupe i would think its a z20let as im not sure a xe20let even exists the mk3astra ones were c20let and the mk4 astra are z20let and
the mk5 vxr is z20leh
it its the zlet i would guess at the coil pack as its 4 seperate coils just moulded into one unit so you can loose one coil still and have you checked
the plugs to see if they are all firing and what the mixtures look like as i would say three will be a proper brown colour and one will be black
if you loose one coil the engine wont start but will run once started just like a bag of shit
check the earth connections on the engine. also try swapping any sensors, im not sure what the Let's have but other GM lumps have crank or knock sensors.
