Type 9 - no 5th gear
Nitrogeno25 - 2/1/13 at 04:29 PM
Hi all,
I was cruising yesterday in 5th at 3K rpm and suddenly revs go to the sky. I tryied to select 5th again, the lever went in the position but it was like it was in neutral with some hissing noise.
All other 4 gears and reverse work OK.
Any ideas??
Many thanks!
[Edited on 2/1/13 by Nitrogeno25]
loggyboy - 2/1/13 at 04:44 PM
Type 5s were all 4 speed!
Nitrogeno25 - 2/1/13 at 04:51 PM
Sorry I don't know what I was thinking. It's a type 9!
Thanks.
Paul Turner - 2/1/13 at 05:03 PM
Loggyboy, Type 9's are 5 speed plus if you were in 5th how could it possibly be a 4 speed.
Nitrogeno25, Sounds like something has catastrophically failed. Looks like further investigation required. When I lost 2nd it was a sinple circlip failure but it was a total strip to replace it.
loggyboy - 2/1/13 at 05:08 PM
His original post said it was a type 5! And I assumed he was mistaken, or in 3rd!!
[Edited on 2-1-13 by loggyboy]
Nitrogeno25 - 3/1/13 at 08:11 PM
Yes, my original post said type 5 by mistake.
Back to the gearbox, I've been told that the 5th gear needs adjustment from the right side of the box?
