I'm sortin out an exhaust for now whilst I get one built.
What's the best way to fit 4 exhaust manifold bits to new bits?
I thought a swager would be cheap ermmm no.
I can't weld that well so don't wanna so that....
I saw some adaptor a to join pipework which are £12 each well it's only for a day at a track day then ill get a new exhaust.
Help please peeps .....
[Edited on 7/2/13 by jossey]
David are you talking about joining straight tubes with something like this eBay Item or a collector to take a new manifold own to an
exiting exhaust pipe like this eBay Item
Rich
Sorry I was a little unclear. Yes joining my old manifold which is cut up to new pipe. So the first connector should work.
Thanks rich
Yes but I would suggest you use Mikalor stainless steel T-bolt clamps rather than U-bolt clamps.
Ok will do.
