Hi all
I don't suppose anyone can id my thrust bearing please?
It came off a silvertop zetec/type 9 combination. However the combination of flywheel etc that was used was incorrect as it mullered my ring gear and
powerlite starter!!! So I've had to completely start again using brand new items from Dunnell. So what I'm looking for is the standard
thrust bearing for the type 9 box, I'm hoping that this may be the one but I'm doubtful.
Any help appreciated
Leon
There is no 'standard' thrust bearing for a type 9, it will vary from car to car that used the type 9.
What flywheel, clutch and plate are you using?
This is the kit I've got
http://www.dunnellengines.com/zetec_components.php?partno=RMP1305
The flywheel is a 2.0 zetec and I believe the clutch plate and cover is that from a pinto, although I have just emails Paul Dunnell to confirm.
cheers
Leon
Looks like a CCT-133 to me!
I had a funny feeling it would be the cct133. Is there a shallower alternative thats used?
Correct release bearing for standard 1.6, 1.8, 2.0 zetec flywheel and pinto diaphragm is CCT132.
[Edited on 2/5/13 by Dusty]
Splendid
Does that refer to a Ford part number?
they are quinten hazel (qh) part numbers
