I have a Raceline water rail on my Zetec, but need to blank off the rearmost sender outlet , any suggestions on a cap/plug that will give a flush fit ?
Get rid of the Raceline rail, they cause nothing but problems (look nice though). The Ford housing is designed for the job and has bypass pipes to
ensure circulation during warm up, the Raceline rail doesn't.
Mine has been running perfectly for 12 years now with no issues, know too many people who have junked the Raceline rail to ever consider one.
Look at my gallery to see what a car can look like with a Ford housing.
And on the other side of the coin our Race Zetec ran perfectly with the raceline water rail and made the install nice and simple.
I had all sorts of cold running and overheating problems with my Raceline rail. Put the original thermo housing back on and all was solved.
Found out later the problem was the thermostat in the water rail is too far away from the head to work properly.
Regardless of the rights / wrongs of the Raceline water rail, I think Arrdvark is after something like this:
1/4 NPT plug
Check the thread size, it might be 1/8" I can't remember.
Phil
(p.s. been running a Raceline rail on my Zetec for 11 years with zero problems)
The design the of Raceline water rail has a couple of major draw backs, first of all there is no by-pass circulation around the thermostat this
effectively stops the thermostat working as the thermostat will remain cold when the engine block is at or near boiling.
This can be worked around by drilling the thermostat but is better to also drill and fit water outlet close to the thermostat and lead this back
to a water pump inlet to provide a proper by-pass.
The second problem is the water passageway is small bore and restricts the coolant flow but this should only be a problem on very high output
engines.
Thanks Phill, thats the answer i needed
