Interesting idea put to me by a friend. Why not mate a tweaked vauxhall diesel to a Carlton gearbox and chuck the whole lot in a seven style
roadster. ??
After a bit of thought... Economy would be good, plenty of torque, revs would be down a bit but peeky enough if driven 'on' the turbo. But
what diff ratio would you need given a top rpm of say 4000 and a probable 1:1 ratio in top gear? If max speed wanted was say 120mph (let's face
it, any more and it's asking for trouble)
Yeah I know everyone's going to say 'engine will be heavy!' But so are pintos compared to bike engines. I thought it might be fun to
try something different.
No doubt someone's already done it???
Didn't one of the kit mags run a feature on a VAG diesel 7 build some years back?
Seem to remember the Weisel - a westfield V8 chassis with some sort of tweaked ford diesel in it - getting publicity maybe (gulp) 20 yrs go. I think it span it's wheels in 5th or something ridiculous like that!
The closest I can think of was a MEV kit car fitted with a Focus TDCi engine, that was also in a magazine. But I spoke to the guy a year or so after
he'd finished, and while he did like the idea during the build, it didn't turn out as well in practice. The diesel just didn't suit a
lightweight car.
[Edited on 26/1/14 by Slimy38]
i reckon the current bmw 320 diesel engines would work well power delivery wise in a 7 they rev and drive more like a petrol than any other diesel i have ever driven.
Been a topic for a while now - check out Benzine's posts
Next project will prob involve a diesel.
7 will be fine with one, just have a low diff ratio to counter the torque and the lower revving engine.
Simon
I think Dinosaurjuice on here have a TDCi powered MEV Rocket.
Benzine's just put a peugeot xud engine in his. Goes well too
The weasel was in ppc a long time ago, a Vag 1.9 turbo motor, not sure what happened to it but it looked good to me. And, if I remember rightly it was
fast and did 90mpg.
I'm surprised none of the manufacturers took it up, after all they make good power and the torque would make a lightweight 7 fly!
A thread here
http://www.locostbuilders.co.uk/viewthread.php?tid=118097
Originally posted by coozer
The weasel was in ppc a long time ago, a Vag 1.9 turbo motor, not sure what happened to it but it looked good to me. And, if I remember rightly it was fast and did 90mpg....
Depends why you want the car. If you want it to be fun why on earth would you fit a diesel? If you are interested in economy then go for it.
Stu
Do it. I can't think of a more low cost way of getting, say, 150bhp. Can anyone think of a cheaper, easier way?
Mechanical IDI engines are so easy to work on, cheap to buy an engine, cheap to tune (until you get into forged rod territory). Examples:
My engine (XUD): £80
Turbo, injectors, inlet plenum: £20
Injection pump: £15
Gearbox: £50
With some spanner and screwdriver tuning it'll be in the area of 120bhp (around 200lb/ft). Bolt on a bigger turbo (T25, TD04) and you can see
160-180bhp (around 250lb/ft). Then fuel pump mods and you could see 200. Then there's propane injection, methanol/water injection, nitrous
I'm running about 120bhp at the moment, I've been parts collecting and I'll be putting on a bigger turbo and a supercharger soon, along
with a pi diff. £1 a litre veg oil, or cheaper used. Economy & parts prices are v important to me
what about a beetle fitted with a t2 Bus gearbox and 1.9 tdi engine ?
ignoring the weight bias (unless you turn it it over to make it mid engined) , chop the body off , porsche prototype bodywork replica and 100 mpg....
not bad for a cummuter car ...
Stu
Here is my favourite derv powered car, as you can see the performance advantages are immense!
Just in case...
Got to be honest, I just don't see the point. IMHO, diesels only make sense in either a heavy vehicle where torque is important or for someone
doing very high mileage ( >15k per year) where the fuel savings make it worthwhile. Beyond those reasons, the only other reason I can think of is
the "because I can" type reason where it it simply a curiosity or itch that you want to scratch. Nothing wrong with that as a reason I might
add.
I say the above as someone who drives a BMW 535d as my commuting car (18k miles a year) and someone who has a Rover V8 engined locost. The V8 comes
into the "itch I want to scratch" territory because really the engine is not ideal for a locost if max performance was what I was after due
to weight, bulk and low specific power. However, the sound and feel makes up for it for me and it's still pretty fast. I was aware of the pros
and cons of my engine choice right from the start so I'm happy with the compromises.
In my opinion, the ideal engine for a seven is probably a high revving, VVTi normally aspirated all alloy petrol engine with a high degree of
traditional tuning applied (heads, cams, lightened and balanced etc). If you deviate from this theoretical ideal engine then you should have a good
reason to do so and be honest with yourself about those reasons from the start.
The diesel will be similar in many ways to my RV8. It will be relatively heavy, with loads of torque but not so much outright power (I've got
around 180BHP). However, my V8 power is instantly available due to no turbo. The diesel will be more economical but for the mileage a typical locost
does, this is unlikely to matter. The installation will be a lot more complex too due to high pressure injection, engine management and turbo etc.
It's all a series of compromises really whatever you decide so just make sure you've thought it all through carefully to avoid any potential
for disappointment later. In the end, when you've considered all the factors, the only opinion that matters is your own.
Agree with most of what you say, craig
Originally posted by craig1410 The installation will be a lot more complex too due to high pressure injection, engine management and turbo etc.
Good points on all sides there guys, although complexity of installation doesn't come into it really.
I am a HGV mechanic anyway so diesels are the norm for me. My current build involves a zzr1100 bike engine and I've been sat with my head in my
hands on a couple of occasions wondering why I'm going that route.
It will get completed, no doubt about that and I'm hoping to be at Stoneleigh with it. As for the whole diesel idea.... Like I said in the
beginning, I know a guy who tunes diesels, remaps, etc and has a shed full of vauxhall diesel blocks, pumps etc. cheap.
As you all realise cheap is the attraction, it may not be the 'sexiest' or 'fastest' but for anyone who has just been
'knobbled' by the sneaky bastard camera van the emphasis on top speed is a little mute. Style and handling on the twisties, economy, and the
technical challenge of building it yourself is where I'm coming from.
It may be the next project, it may be a dream that will never be fulfilled. Maybe it's because I can/could. Possibly.....
Got to be honest, I just don't see the point. IMHO, diesels only make sense in either a heavy vehicle where torque is important or for someone doing very high mileage ( >15k per year) where the fuel savings make it worthwhile. Beyond those reasons, the only other reason I can think of is the "because I can" type reason where it it simply a curiosity or itch that you want to scratch. Nothing wrong with that as a reason I might add.
Originally posted by MikeRJThe Locost (and any 7 style car) is a sports car...
Why ruin the potential of a sports car by fitting a petrol engine when you can have electric? Unless range is an issue, in which case diesel is king
Checkmate, non dieselers.
What's all this nonsense about torque vs revs? Stick the right gearbox on it and you have a flat torque curve and little difference in
performance. You don't use flywheel torque to drive a car directly.
The only real issue, to me, would be noise. And weight. And difficulty tuning anything vaguely modern.
Seems I've opened a can of worms and everyone has an opinion.
I reckon with the correct forethought a 'fun' and 'efficient' mid engined car could be done fairly cheaply.
I say mid engined because let's face it everyone here likes to have oversteer, and a cheap supply of normally overlooked engines and gearboxes
are predominately front wheel drive transverse units. I dare say that the weight issue of having a 'normal' seven style car with an anvil in
the front would cause compromise to handling.
But then I hear you all saying.... Noisey rattley lump just behind my head, I should co co!! But magic can be done with dynamat.
Might be a pipe dream..... Might already be making plans....
yes, indeed, why ruin a sports car with a diesel engine...
Really? Modern diesels just seem to need a remap to gain an instant boost, there are literally hundreds of companies offering the service. Granted getting much further can be a challenge but getting that extra top up is a couple of hundred quid drive thru service.
^^ thats all fair enough when your talking about 10 - 15 year old VAG engines or the 2.5 BMW one out of a vauxhall omega (or other BMW ones in the
rovers etc) - tried and tested engine swaps / installations with old fashioned controls that are fairly simple to separate from there donor car
but the more modern, higher performance ones have the ECU more and more integrated into the rest of the car - making it harder and harder to extract
all the donor bits and get it running
diesels don't really give you the option of just throwing all the OE bits in the bin and starting from scratch with a generic ECU like you can
with a petrol
and even if you do get it running and the chip tuned as far as you can - whats you next step if thats not enough power ?
having said that this new generation of turbo'd small eco petrols is probably just as hard to deal with....
[Edited on 29/1/2014 by mcerd1]
ive done nearly 8k miles in my diesel Rocket now. loved every mile.
I had it remapped 2 years ago, no idea what power its producing but its significantly more than the standard 136hp.
Economy is so good i don't even think about.
Noise isn't an issue. its a bit clunky when cold and idling but that's it.
I'm amazed that I built it 5 years ago and there arnt more diesel kitcars on the road
But it could also be an incredibly fuel-efficient lightweight commuter that also happens to offer better performance and handling than the best current hot hatches (at the price of all creature comforts, of course).
Originally posted by MikeRJIt would be one of the most impractical commuter cars ever. The aerodynamics are tragically poor compared to most tin tops so fuel economy is always going to be compromised...
Originally posted by MikeRJcrashworthyness is negligible
Originally posted by MikeRJ... most have insufficient ground clearance to deal with the ever increasing number of speed bumps and pot holes
Originally posted by MikeRJ... and their very low height means visibility is compromised in traffic.
Good thread!
Lot's of interesting responses.
What I would like to contribute, is a choice of engine.
Despite everything the lightest option will be the best,
So I recommend the Mercedes 170/200CDI engines. (Mercedes-Benz OM668/OM640)
They have the best p2w ratio.
If you're in to aircraft... the Cessna diamond use to have 2 of these lumbs by Thielert (Centurion).
When this option came to marked the designers specifically chose the engine for the p2w
(It bit them in the backside as it was never a very good plane engine).
You can find them in A-class and (I think) C-class mercedes.
What's all this nonsense about torque vs revs? Stick the right gearbox on it and you have a flat torque curve and little difference in performance. You don't use flywheel torque to drive a car directly.
But I go back to my original question; would a diesel (and preferably streamlined) 'Eco-Seven' be any less valid as a design solution than the Renault Twizzy and other electric micro-commuters?
Does the Twizzy (or G-wizz, or any 'heavy quadricyle'-class commuter car) score any better on any of the issues you raised?
Ive never had a problem with my engine not building revs fast enough.
If I had the time I would really like to build a fully enclosed kit car, probably with the 1.6 PSA hdi/tdci engine, and use it as an everyday
commuter.
Originally posted by mcerd1...if you want to talk about commuter car's then yes the Twizzy's and smarts are more practical...
And like you, I take a more conventional route at present for my 'shopping' car: a petrol Toyota Aygo, which gives 68mpg on the motorway and about 55mpg overall, but doesn't have any performance that you'd notice.
Originally posted by mcerd1i don't think 'conventional' applies to my reasons...
getting back to diesel vs petrol...
I've driven diesel tin-tops with far more power than my petrol ones - but somehow they all feel dead to me
and yet I know people that love the modern diesels... so I guess its another BEC vs CEC at the end of the day
the old 106 had no fancy bits to get broken - in fact my old carb'd one only had 2 electronic things on the whole car - the ignition amp (on the side of the dizzy) and the radio
I think I'd still rather have an old 106 over any of its replacements - I actually like little tin boxes with manual steering and no frills
if I could get a 106 rallye 1.3 8v on carb's I think that would be very close to my perfect tin-top![]()
Simon - 29/1/14 at 08:32 PMDiesel revs slower, and spin up slower, but has more torque. Therefore, if you use a lower ratio final drive the "revs slower" becomes revs the same at the rear wheel. The spinning up slower is also countered by the lower f/d ratio. The low f/d also reduces the effective torque at the wheels. I had an injected Rover 3.9 V8 in toy car, but a Jag/BMW 2.7/3l diesel would offer similar performance (- a slight weight penalty), but prob twice as many mpg and, as I stated elsewhere, most of the time you'll be pootling along with the rest of the traffic. And sound is lost behind you at anything more than about 40mph, so who cares what it sounds like. Oh yeah, and use an auto box with diesel
I know what I'm trying to say and an analogy might be something like this (which is true).
We have a bloke in the local mtb club I belong to, he's less than 2/3's my weight, and has Bruce Lee's physique. He can spin the pedals very fast. Being the petrol engine with high ratio final drive.
I don't have the physique of Bruce Lee (weighing in at 17st), and like to turn a big gear, being the low f/d. Luke cannot get away from me (until after the first 100 yards when 20 odd years of smoking catch up and I need to fill my lungs up again, but that's an aside) or we get to a bend.
Once I've lost 5 stone, I'll still turn a big gear, he'll still turn a little one, and I'll out run him with far fewer pedal stokes![]()
If I still had Deimos it might well have either of the above engines in by now.
Simon
stevio73 - 30/1/14 at 03:01 PMThis is certainly interesting....
Sports car or commuter car, neither really matters in today's "modern" British motoring conditions. Let's face it, the state of the road surface on most highways is enough to shake your fillings unless driving the equivalent of a queen size mattress. The other factor is that the government have cottond on to the easy revenue produced by those of us in a hurry or enjoying a "spirited" drive by way of sneaky bastards in vans with cameras.
So it's fair to say that for the masses who enjoy the handling of a sports car on a day to day basis and don't want lots of points and fines for excessive speed because it isn't silverstone, oh and also don't want to give Mr tax man their left arm because of fuel costs..... Diesel may be an option.?
There's no mass produced diesel management systems out there that would work on multiple engines, BMW, Vauxhall, VAG, because of a) demand and b) all have different ways of doing the same thing. A generic management 'box' ain't gonna happen. Which does mean tuning will always be an issue. But then.... If we are all sheep and all drive at the speed limit to avoid fines (and the sneaky bastards in vans with cameras) why do we need to tune?
I guess I like the idea, because I like the 'look' of the seven. I enjoy the technical side of building something I can then use. And yeah I like driving fast, but on that one I'm maybe getting old and sensible. I want an everyday driver, I want economy, I want the 'look' I want to be able to say I built that. I've had bikes, and got wet, but always had a smile on my face. I've had a smart car, and always been worried about how much oil it used. I've had bangers and lots of fun in them. I've made money on some, I've lost money on most. I've commuted in vans, cars and bikes. I've yet to complete a seven build and, ashamed as I am to say this having had so many different cars over the years, I've never yet actually driven a seven. Shocking isn't it! I am almost worried that when I complete my current ZZR1100 haynes build I won't like it. But it doesn't stop me looking for what I'd like to do next!!
stevio73 - 30/1/14 at 03:26 PMJust happened across a video on zcars website where he's talking about a diesel powered grass track car. Worth a look for the 1:25 length of it.
Simon - 30/1/14 at 04:53 PMThere is a stand alone diesel ecu available but it's about £2500. Way out of reach of most sensible people's pockets
Simon
Beardy - 1/2/14 at 06:12 AMbit off topic, but what about something like a GT70 with a V6 tdi lump?
this is a less dramatic shift than a petrol engined 7. Looking at the GT40/Lola T70/Cobra type cars which have a big chunk of iron and a slow, heavy gearchange and are in general powerful torque monsters. Here a diesel might not be such a bad fit. Mid engined would put the additional mass in the centre of the axis of rotation and therefore minimize its affect. Loads of grunt and reasonable fuel economy would be a good replacement to a small block chevy for example.
as noted - a bit off topic.
I'm in California and the availability of diesels is poor, otherwise something more modest (3 cylinder Lupo Tdi?), in a J15/Riot might be a laugh.
Mike
drt - 3/2/14 at 03:12 AMquote:
Mike
Agreed, the 1200tdi lumps are peaches... some custom and factory build dieselBikes use them
link; http://thekneeslider.com/thunder-star-1200-diesel-by-star-twin/
Oh, not to be a pain, but you ment the 'polar moment of inertia' as a car turns around the COG.
Also, a rover v8 is often states as weighing in at 220kg? Give or take.
Most 4 cilinder diesel will struggle to go below the 200kg mark.
And these are 'almost bare' block figures.
On top of , a diesel pump (injection system) of any design will weigh more then it's petrol cousin etc...
However I am a fan of the idea ^^
But instead of reaching for performance... make a hypermiler!
3 wheels, 2 seats, minimise weight at all cost, spacesaver tyres.
And a small modern diesel with coasting ability.
Get you inspration here;
http://www.shell.com/global/environment-society/ecomarathon.html
As I was involved with a car for this competition I am a bit biased
