hi i have fitted a brand new polo rad with the fan switch in the rad new rwaterpump new headgasket,i have no header tank but got a filler neck in the top hose from thermostat to top of rad, the head seems to get over 100+.i was wanting to no where everyone is putting their fan switch in the rad or neer the thremostat? as the rad is not as hot as the head when the fan kicks in thanks in advance as it is giving big head ache now and need to get it sorted before put back opn the road.
i had loads of issues with my pinto overheating,
i ended up getting a cool running thermostat from burton power a lower temp fan switch for the rad, moving the rad fan to the rear of the rad and
sitting the rad vertical as mine was slanted back slightly
i also fitted an ashton racing water pump and now she runs nice and sweet.
another thing to check is the coolant take off on the inlet manifold side of the head and i would probably fit a header tank to help eradicate air
locks as having a filler neck in the top pipe is a little low.
i have heard people sometimes drill a couple of small holes in the disc of the thermostat to allow air bleed, i havent done this myself.
Have you got the 16mm pipe from pump to head inlet side?
If no, fit it
If yes add T piece with cap
Rad is lower than head water jacket so header tank would help
i ended up getting a cool running thermostat from burton power a lower temp fan switch for the rad, moving the rad fan to the rear of the rad and sitting the rad vertical as mine was slanted back slightly
another thing to check is the coolant take off on the inlet manifold side of the head and i would probably fit a header tank to help eradicate air locks as having a filler neck in the top pipe is a little low.
I brought it from Ashton racing direct I think it was about£80
Edit - Ashton contact email address
Ashtonmobile@hotmail.co.uk
[Edited on 16/3/14 by carlknight1982]
Check the thermostat is the right way round as well, it's easy to get wrong on the pinto
Also, make sure cool air can freely enter the radiator. Some types of expanded grille mesh can be very restrictive.
Then make sure hot air can escape by having vents in the side/top at the rear of the bonnet.
82 deg stat makes a difference, as does a decent header tank and internally mounted sucker fan
Drilling a small hole in the top of the thermostat also aloes air to bleed out helping to stop air locks.
Engine bays are generally smaller than the donor and airflow through more resticted
I found I needed a big radiator, an earlier opening thermostat, heat wrap on exhaust manifold, an oil cooler, ducting air so it can only go through ®
the radiator not round it and finally a way of hot air leaving the bay
I had similar problems with my pinto. The issue was that there was no flow getting to the thermostat and hence it wouldn't open. I connected the bleed on the thermostat housing back to my header tank. Water is constantly pumped through this line so it warms the thermostat. I also have the heater hose looped to the manifold. This setup works beautifully.
ran it up tnite it takes 10 minutes to get to 100c and seems to pressurise rather quick, the rad is luke warm at the top and cold at the bottom so im
tyhinking of water flow? amd snapper i have fitted a t peice for the air bleed.
[Edited on 17/3/14 by biksz]
Have you tested your thermostat in boiling water or with a heat gun to ensure it is working because it sounds like it isnt
yeah first thing I did before fitting it.
Is head really at 100 ? I put 82 thermosta from Bruton in mine with two small holes for flow
But I had heat gun on head and gauge is ten degrees out . Plus when stood I have switch on dash
So can put fan on at 90 and stood still it will stay at 85 if I wait for fan switch I worrie it will get to hot
Fan switch is in just for back up
waiting for a infa red thermometer to land so can run up and check but till then cant do much more than double check timing and mixture but not sure how many degress to do it think its either 4 or 8 at minute.
Where are you based you can borrow my snapon one, I will check
My paper work from h and h but think mine is 12 degrees
thanks for the offer maximus i am at doncaster bit far i think its ok i can wait for the one on order to land as no rush i got two month to get it sorted
