Hi guys,
Can anyone give me some good advice on how to succesfully take 40mm from the original 1600cc xflow pickup pipe? (The type with the deeper mesh on the
strainer, not the flat pancake type)
Have people heated then tried to bend the pipe to sit lower? Can you chop the pipe behind the gorse part then tack weld the strainer back in
place?
Any help greatly recieved please.
Kaino
on zetecs they tend to cut it then sleeve it and get it brazed or soldered
dont wasnt it dropping off !!
On my Zetec I got a guy to tig weld it after chopping it. Seems to work fine.
Not the same engine, but I had my sump shortened and the guy chopped and rewelded the pickup.
I used soft solder to fix a metal sleeve over the join after shortening - I can't remember if I used brass or steel for the sleeve - it's not going to get hot enough to melt. At least, if it does get hot enough then i'd have other things to worry about!
Again its zetec, but I just mig'd mine.
More pics.
http://www.loggyboy.com/images/Raw/Sump
[Edited on 27-3-14 by loggyboy]
