The front bearing on my propshaft has some play in it, and as its out of the car at the moment, needs to be fixed
My local place that makes and repairs propshafts etc, is unable to do the job, as he can not get a new reverse sleeve for the gearbox end as
unfortunately, it seems that the joints I have are sealed, and non repairable, and the circlip type was never made for my gearbox/axle combination
(well, that's what ive been told !)
I am running a type 2 ford gearbox, 16 splines 30 mm shaft and an Ford Atlas axle
Has anyone, either got a prop shaft I can buy, that will fit the ends ? or a place were I can get one made ?
steve
Hi Steve,
I got one made from scratch from a guy not too far from us... I'll go and check where it was!
I think it was these guys in east grinstead....
http://www.autoprop-uk.co.uk
From memory I paid not much over £100 for a freshly made prop
Thanks Andy, its the same place, who is unable to make mine
Its the front bearing that is the problem, as unavailable
steve
Bailey Morris in St Neots may be able to help ?
Can he not make a new one for you?
Wilson Brothers of Bulwell, Nottingham
H J Chard Bristol , they are the boys. Have used them several times for Westfield and other cars.
http://www.prop-shaft.com/
u2u sent
have you tried escort tech out in faygate? they may have parts to help you get it fixed.
