The ST170 engine I have already had a spigot bearing in the end of the crankshaft. I bought a new one as I assumed the output shaft of my type 9
gearbox wouldnt fit into the existing bearing. I've taken the old bearing out today and.....it slides snugly over the type 9 gearbox shaft.
Comparing the old and new bearings they look identical, is there any difference. My engine had the fwd gearbox attached to it when I bought it
Ian
No it’s the same bearing and for some reason it’s a factory fit. I don’t know why as the first motion shaft doesn’t locate in it.
Out of interest, how did you get the old one out ? It’s worth changing as mine is full of clutch fibres / bits.
[Edited on 17/1/18 by big_wasa]
I used a slice of bread..... No honestly I did.
I Googled Spigot Bearing Removal last night and it brought back some you tube videos of bearings being removed by packing the hole in the end of the
crankshaft with moist bread (or grease) and then knocking a bolt same o/d as the bearing bore into the hole. Basically the bread had no where to go
and it forces the bearing out. Thought I'd have a go and it actually worked. I had to turn a piece of nylon rod down to a very close fit as the
bread tends to ooze out around the bolt if is too loose a fit and you'll need to keep filling the hole with bread but it does work
[Edited on 17/1/18 by Barksavon]
When you say the first motion
shaft doesn't locate in the bearing are you referring to the fwd version cos it looks like the output shaft of the type9 on the rwd conversion
will.....
Yes the st170 box doesn’t use the bearing so why did they fit it ?
Thanks for that, I was a bit unsure whether I'd bought the wrong bearing .... I'll fit the new one tomorrow.
