I've got my ST170 up and running on ZX6R bike carbs, Ford ESC ignition and a VVT Pro controller.
Just managed to get a cheap megajolt and wondered if anyone has a map set up with the VVT working?
Thanks in advance.
I have a couple of maps on my ecu I could send. Not specifically MJ but would enable you to get some sensible numbers together.
I run an ME221, with VVT enabled.
I've got a regular BT Zetec MJ Map if any good. I'm planning on injecting mine so will need to work out how I convert the MJ map to Speeduino this winter.
Thanks but it's only the ST with the VVT on that I'm really interested in tbh as I think it could be quite different to a normal ignition map. I might be wrong but thanks anyway.
Hi Nick, I'm in the process of fitting an ST170 engine in my Avon (slower than I'd like though) I'll be running it on bike carbs with
megajolt ignition and a vvt controller, so very similar to your set up. If you get any MJ maps would you give me a shout please. I'm a long way
off that stage at present but hopefully....one day....I'll be where you are now.
Ian
Originally posted by Barksavon
Hi Nick, I'm in the process of fitting an ST170 engine in my Avon (slower than I'd like though) I'll be running it on bike carbs with megajolt ignition and a vvt controller, so very similar to your set up. If you get any MJ maps would you give me a shout please. I'm a long way off that stage at present but hopefully....one day....I'll be where you are now.
Ian
Thanks, I'll be watching your posts with i terest. My MJ is the same, I had it running on my Pinto with bike carbs and it ran very well, hopefully will be the sale on the ST170.
i ran a st170 with the Mtech vvt controller and megajolt with bike carbs on the base 2ltr zetec megajolt map and it ran very well
