Hi
Does anyone know if the standard zebec crank sensor pulse is set at 90 degrees BTDC or something else like 80 or 85 degrees?
I'm currently setting up my new ECU and throttle bodies and need to enter a setting.
Should be 90 for a 4 cylinder motor with a 36-1 tooth setupso set it at that and see what happens.
Thanks, I thought 90 degrees too but the Emerald software seems to default to 85 which has spooked me.
Ring Emerald they are always ready to help. 01953 889110
