I have fitted a Raceline wet sump to my Zetec. Is there a way/ need to prime the pump? I have removed the plugs as I wish to get the oil circulated,
how long on the statrer untill pressure would build up?
Regards Jon
My zetec was sitting for a few months. I pulled the ECU fuse so it wouldn't fire the fuel pump or spark and it took about 3x 30second cranks to
get the oil pressure guage reading 30lbs.
After that I plugged in the fuse and started the engine.
Would you expect the old oil to have left the pump? They're self-priming once they've run once in their life, I can't imagine any need to re-prime personally.
Thanks for the relpies, I may drain the oil and refill so that the cams are covered in oil. Thought about taking out one of the oil gallery plugs and putting in a threaded adaptor with a hole, atatching a pipe to a funnel and filling with oil. Does anyone know the thread in the oil gallery?
I spin an engine over with plugs removed. Takes the pressure off the big ends/mains, and the engine spins much faster.
I wonder if you can prime the pump via the oil filter, or even the oil pressure switch connetion?
