help on throttle cable to fit twin 45's please
Brooky - 21/3/05 at 09:28 PM
Hi guys, a mate of mine has just bought a Tiger Six with twin weber 45's and has bust his throttle cable (his nipple has fallen off! ooooeerrrrr mrs)
Any idea what size the nipple is and where to get a new one from?
Cheers.
Hellfire - 21/3/05 at 09:55 PM
You could make one - alternatively you could always give VWP a call. They provide an excellent service and their prices are reasonable!
britishtrident - 22/3/05 at 09:26 AM
If its the original Lotus style linkage where the outer cable moves the quadrant and the inner is fixed just drill and slot a suitable bit of bar (ie a bolt).
Otherwise a trip to your local cycle shop might be the qickest fix.
Brooky - 22/3/05 at 01:10 PM
Yes the bike shop was going to be the planned route. The problem i have is his car is 30 miles away and he wants me to fix it for him. I was after a size of nipple (6mm - 7mm 8mm etc) to start with to save the 45 min of filing and grinding I had to do when I did my throttle cable, but seeoing as mine is a BEC i cant use my linkage as a guide.
DaveFJ - 22/3/05 at 02:54 PM
As an aside this is a common problem with Tigers (and I assume a lot of other cars as well). It happens because there is no throttle pedal stop or it is innefective so the cable takes all the strain and evetually fails.
I suggest you also tell him to fit a simple adjustable stop to his pedal - a bolt on a bracket with a couple of nuts for adjustment should do the trick.
