I'm fitting an electric water pump so I would like to remove the water pump pulley which is attached by a magical force on the end of the
camshaft.
I can't see any visible means of fixing like grub screws or bolts so it might be a keyed interference fit or just screwed on a thread.
Any ideas guys?
What engine?
bigger persuader needed
its an device with 3 or 2 arms and one center bolt..
when screwing in that bolt you pull on the arms...
its made for suchs conical fittings...
15secs to take of that thing..
Tks
Sorry - V6 Duratec ..... and I tried a big rubber persuader
Originally posted by tks
Puller?
Haynes describes and shows it being removed with a puller from the end of the camshaft.
Thanks Dusty - I must have missed that in the manual - I'll try and find my puller now
