Zetec clutch
Danozeman - 30/1/06 at 02:40 PM
Is this site correct for the clutch part no etc?
Im going 1.8 zetec to type 9. Any help muchly appreciated.
Tiger Super Six - 30/1/06 at 03:19 PM
When I put mine together I used a Pinto clutch. You are better with a lightened flywheel and if you buy these from Burton, Raceline, Scholar etc they will lighten it and sort it to accept the the pinto clutch.
You will need the spigot bearing as mentioned and a started motor off of a CVH engine (although I think there are a few that work, but not a pinto).
I replaced the flywheel bolts (just went to the local dealer).
HTH
Mark
Danozeman - 30/1/06 at 04:15 PM
I dont really want to go for a lightened flywheel as my budget is very limited at the minute as in im bleeping skint. So the cheapest reliable option is preffered.
Tiger Super Six - 30/1/06 at 04:17 PM
urm, not sure as I went the lightened route. I bought mine from Scholar for £95 exchange so thought that not too bad as I wouldn't want to take it all apart again at a later stage just to change it.
Mark.
Doofus - 30/1/06 at 04:24 PM
I've used a standard 1.8 flywheel with a
Mondeo 1.8 clutch plate 220x25.4x23 Q’Hazel part number C1189AF
and
clutch release bearing Q’Hazel CCT 133.
I got the spigot bearing from Quantum Cars so I'm not sure of the ford part number.
Again the Starter was off a CVH Sierra but the sump was a modified alloy one to make room for it.
It's all built up at the moment waiting to be started and looks ok
Paul
[Edited on 30/1/06 by Doofus]
Jed - 30/1/06 at 07:30 PM
If you have a 1.8 engine and it isn't the 130PS one then you should have a lighter flywheel anyway. Still not as light as a lightened one but its fine for most people.
Spiggot bearing from Ford is part num 1596468.
I used a Sierra 1.8 CVH friction plate and kept the pressure plate supplied with the engine.
givemethebighammer - 30/1/06 at 08:28 PM
and
same here escort 1.8 flywheel, 1.6 / 1.8 Mondeo cover and plate, capri 1.3? release bearing CCT133 and pinto spigot from Ford.
Over 2000 miles on and no problems yet.
Danozeman - 30/1/06 at 09:25 PM
MIne is a 1.8 mondeo flywheel. These are the same as escort IIRC. Ill get a mondeo clutch and see what happens.
Cheers for your help.
bob - 30/1/06 at 09:27 PM
Make sure its early mondeo though (220mm) i think later ones after 97/98 are bigger.
big_wasa - 30/1/06 at 10:19 PM
Make sure it has the 1" 23 spline center in the plate as many are smaller.
Danozeman - 30/1/06 at 10:20 PM
Ill have a look at my old clutch and see what its like. Ill get a match for that if it fits.
Does the realease bearing need a spacer?
Doofus - 31/1/06 at 02:21 PM
I don't think so
and
using a release bearing CCT133 the same as mine which seems fine
givemethebighammer.
Did you need any extra spacing?
Paul
givemethebighammer - 31/1/06 at 09:08 PM
nope, the capri release bearing is about 10mm or so longer than the sierra one that was attached to my type 9 when I got it. I just fitted the capri one no extra spacer needed.
Danozeman - 2/2/06 at 08:40 AM
Excellent id better go shopping. Looking to get it all poperly fitted and wired up over the new couple of weeks. Hopefully even running.
Thankyou.
Jed - 21/2/06 at 08:27 PM
Just for completeness just incase someone else needs it, these are the QH part numbers:
Friction plate C1189AF (as mentioned earlier)
Cover plate Q10066
The above are in QH kit QKT690AF.
