I have just completed a engine swap from the TVIS engine to the non TVIS engine. I used the original loom from the TVIS engine as far as possible and
grafted the new ECU connectors onto the old loom (the connectors are different size), i matched everything up wire for wire and the engine starts and
runs. The problem is that the tickover is about 2000-2500rpm and after the engine heats up it starts 'hunting' (dont know if thats the
correct term), basically the revs start fluctuating quite dramtically. It seems like it is maybe sucking unmetered air from somwhere, but i certainly
cant see anything obvious. More likely to be an ECU related issue.
Has anyone out there got any ideas or suggestions? I know its difficult to pinpoint on my poor description!
As soon as i blip the throttle it revs quite happily.
By the way i have fiddled with the distributor and it is currenlty sitting in the middle of its available slot travel.
Any help appreciated.
BTW - I havent driven the car yet with the new engine, so i have no real idea how it is going to perform under load.
[Edited on 1/4/06 by albertz]
Albert,
Sounds like you have one of the small air ports open. Does it sound 'hissy'. Mines very quiet on tickover air wise.
I'm off out just now but when I return I'll check the ports and list them with pics.
Rob
Rob
Thanks that would be very useful and appreciated.
Andrew
