xflow water pump and timing case gasket
fosko - 2/6/06 at 05:46 PM
Hiya sorry if this post seems a bit simple but i know very little about the xflow. I'm planing tommorrow to change the gasket for the water pump and timing casing. Does the chain run in oil? and will i have to drain the engine first? never worked on a xflow before.
Thanks Jed
Marcus - 2/6/06 at 05:50 PM
Most of the oil will be in the sump.
Change away!
Marcus
fosko - 2/6/06 at 06:00 PM
Thanks for the speedy reply i'll be able to get changing nice and early and on the road tomorrow
