ello, just about to order my Pinto manifold from Bogg Bros. I am fitting zx9r carbs on to them (or rather they are!).
I need to let them know if I need a servo output or a water outlet.
As I am not running a servo I guess the servo outlet is a no.
Do I need the water outlet (the one in the middle of the manifold)? Where does it go to ?
Cheers in advance, andy
yes you'll need the water pipe in the middle of the manifold or you'll be forever boiling it up due to poor waterflow.
i do believe it goes straight to the waterpump.
This is the outlet that presumably comes out of the cylinder head?
The outlet on the inlet manifold goes to the heater matrix. You dont need one at all. Mines blocked off.
Hi seconded you dont kneed it if the rest of the plumbing is correct.
cheers matt
If it doesn't cost any more you could have it put on and blank it off yourself... just incase you should ever want a heater.
If your not going for mega lightweight (*insert pinto jokes*)
Then you may choose the luxury one day for those chilly summer evenings on the way home!
hi i put a water pipe on my manifold it stops air getting trapped it the head + i have it piped to the header tank my car dose not over heat have a
look in my photo archives
Jacko
I got them to put the outlet on for my ZX9R carbs
Mines for an injection head:
Originally posted by mcerd1
I got them to put the outlet on for my ZX9R carbs![]()
Probibly best to plumb it in (even if you don't have a heater)
but if you did want to blank it a very short bit of hose with a plug in one end and a couple of hose clips should do the trick
