hi all,
i know how its meant to be plumbed in - im just looking for inspiration on how to actually route the pipes.
so if you have some pictures, please can you let me see, or tell me where to look in your archive.
Ian.
this is my rough set up, the bottem pipe needs two outlets put in for the header tank and the bottem hose off the stat housing
http://gallery.cantcatchme.net/index.php?cat=9
hi what is the rad off please ?
mine was custom made for my chassis, seemed easier then sorcing one
ok thanks
Hi here is a pic of the way i do the race cars with a zetec. Verry simple and reliable.
cheers matt
Darryls engine bay L/H side
[/img]
cheers guys.... keep them coming....
i had ordered a tiger 32mm pipe with 2 15mm take offs - for the bottom hose. I was not gonna use it because of space, but i decided to cut it in half
and take a 4cm chunk out of it.
im really greatful for the pictures.
Is that a specially made takeoff from the block Matt and does it have a thermostat in the system? It looks simple enough to be trouble free.
I did the same with the Tiger pipe, also allows you to twist it to give a better angle for the
pipes.
Use the standard thermostat housing and stat.
Here's ours, not quite finished at the time of the pics.
We're using a Micra rad, inlet and outlet are at different sides to the Polo rad.
coolant hoses
coolant hoses
top view, hoses done
Hi yep just an alloy plate with a 28 mm hole to reduce the flow suficently. Then the runs to the header tank with the input from below then turned up
at 90deg to allow water air seperation.
Then straight down to the rad and out again to the block.
For road use it would pay to incorporate a thermostat in to the system but for race use its not needed.
cheers matt
