Hi all, i may have a 2.0 head on my 1.6 pinto, and i what to no if i have a 2.0 camshaft in it, is there any way to tell?
And would this explain the timming marks do not line up?
would this make any diffrence to the engine, such as power gain or not?
thanks
stuart
As far as I'm aware they use the same head and cam, only the bore was different. In what way does the timing marks not line up?
I usually pop a metal rod down the spark plug hole to check that number 1 pistion is at the top, check that the rotor arm is pointing at number 1 on
the dizzy, turn the cam till both valves are closed and the dots all line up. Then put the belt on, once done I slowly rotate the engine back and
forwards and the dots still line up. Sure you have the right belt or pully?
[Edited on 2/4/08 by Mr Whippy]
Picture below
And another
And another
Thats a fair bit out there according to the marks.
With the original ford cams you could tell a 1.6 cam from a 2.0 cam. Basically between the lobes between 1 & 2 cylinder or 3 & 4 cylinder (i
can't remember which it was without looking at a camshaft) there should be a couple of little nipples. The 2.0 cam had both intact, the 1.6 cam
had one of the pair half ground away and I think the 1.3 had both ground away.
This method was ONLY applicable to the original Ford cams.
Hope this helps
PS I would check that the TCD mark is in the right place by the previous post method. Plugs out, long thin screw driver fell for TDC as you turn it
over by hand slowly and then see if the bottom mark lines up.
With the original ford cams you could tell a 1.6 cam from a 2.0 cam. Basically between the lobes between 1 & 2 cylinder or 3 & 4 cylinder (i can't remember which it was without looking at a camshaft) there should be a couple of little nipples. The 2.0 cam had both intact, the 1.6 cam had one of the pair half ground away and I think the 1.3 had both ground away.
Hope this helps
PS I would check that the TCD mark is in the right place by the previous post method. Plugs out, long thin screw driver fell for TDC as you turn it over by hand slowly and then see if the bottom mark lines up.
Hope this helps
i used a long screwdriver in no1 and checked tdc was right.
and the engine is a 1.6 longe stroke engine, does this make any differnace?
stuart
i have the 165 block, can that be bored out to a 2.0?
and what type trubo?
stuart
