dave107
| posted on 12/12/08 at 06:21 PM |
Diff spacers
Fitting diff and need to make up space with 17mm spacers each side, i have been supplied with washers to do this but i think it would be better done
with a large spacer and a washer each side, the washers are steel plated would the spacers be ok using aluminium or should i use steel.
tomgregory2000
| posted on 12/12/08 at 06:41 PM |
i just used washers (SHIMS) and is fine
stuart_g
| posted on 12/12/08 at 07:19 PM |
I too used washers but think a spacer would be better
mcerd1
| posted on 12/12/08 at 10:06 PM |
best to make spaces form steel I recon and make sure thay are at least as big a diamiter as the washers
(I'm planning the same for the dax)
[Edited on 12/12/08 by mcerd1]
dave107
| posted on 12/12/08 at 10:11 PM |
Diff spacers
I thought ali might be ok as it would be between two steel washers, and i happened to have a lenghth of 25mm aluminium bar.
mcerd1
| posted on 12/12/08 at 11:04 PM |
that should be ok, the danger is that part of it squashes/ digg's in to the spacer and/or the diff housing which can leave the bolt loosse - its
happened when people forget to fit the washers between teh diff and what ever bushes the are etc...
(assuming it a similar setup to the dax that is - I can't remember exactly what teh MMR ones are like)
bassett
| posted on 13/12/08 at 12:31 AM |
Are you using one long threaded rod or individual bolts. I used bolts with a thick nut and washers either side to take up the slack which seems to
work very well as the diff is going no where.
Adam
Wheels244
| posted on 13/12/08 at 11:32 AM |
I went to the bother of making bespoke stainless steel spacers - when I went to fit them, the mounting brackets and diff faces weren't square to
each other, I ended up using washers - bit of a waste of effort !
[Edited on 13/12/08 by Wheels244]
dave107
| posted on 16/12/08 at 01:20 PM |
Diff Spacers
Thanks for replies.
Going for nut and washers on each bolt fits easy and having the nut locks off bolts very nice.
