james h
| posted on 3/3/09 at 12:25 PM |
R1 question
Hi all,
Is using an original R1 Fuel sender possible with an MK Indy fuel tank?
I have done a few searches, and apparently there is no fuel gauge on the 4XV clocks, only a low fuel warning light.
Could anybody confirm this? And will I need another fuel sender and gauge?
Thanks,
James
r1_pete
| posted on 3/3/09 at 12:56 PM |
Correct, not many sports bikes have fuel gauges.
You will need a seperate sender unit.
Paul TigerB6
| posted on 3/3/09 at 01:09 PM |
you can get a fuel resistant optical level sensor from RS Components for about £14 - you can then fit it into your tank at whatever height you choose
and use the low fuel warning light on the bike speedo.
james h
| posted on 3/3/09 at 01:49 PM |
Would this be a direct attachment to the sender wires from the clocks? I am not too up on electronics.
James
001Ben
| posted on 3/3/09 at 07:25 PM |
yes it would - very easy to wire. supply from back of the clocks and an earth
james h
| posted on 5/3/09 at 01:35 AM |
Ah terrific, one more thing to my shopping list
James
