joemotion
| posted on 5/3/09 at 09:43 PM |
self centering
how easy is this to sort? Mr SVA man didnt like it so need to look at it!
nitram38
| posted on 5/3/09 at 09:49 PM |
Do a search......................then do it properly!
Alter your top bones to increase your castor to around 5-7 degrees if you want a nice handling car.
| posted on 5/3/09 at 10:20 PM |
If you want to get through SVA without making/buying another pair of top wishbones, try adjusting your tracking at SVA to give plenty of toe out and
inflate your tyres to about 30psi.
Just don't drive too far with the tracking set to toe out.
Phil
nitram38
| posted on 5/3/09 at 10:22 PM |
Sva are getting wise to toe out methods and they do drive the car about to see if it feels safe.
| posted on 5/3/09 at 10:36 PM |
Another thing to consider is your steering rack. It could simply be that the slipper has been adjusted too tightly, or maybe the rack has insufficient
lubrication.
If the steering rack is fine and there is plenty of air in the tyres, you shouldn't need a ridiculous amount of toe out to get it to self
centre.
Phil
A1
| posted on 5/3/09 at 11:25 PM |
so is toe out bad? whats the best set up for good driving?
nitram38
| posted on 5/3/09 at 11:45 PM |
Proper Castor............
A1
| posted on 6/3/09 at 12:00 AM |
do you want positive or negative castor? whats best for toe?
Simon
| posted on 6/3/09 at 12:24 AM |
You want the top wishbone balljoint about 5 - 7 degrees rearward of bottom balljoint.
Simon
nitram38
| posted on 6/3/09 at 04:37 AM |
The risk of returning to sva without altering castor and using toe out, is that you are failed again.
It took me 3hrs to modify my top bones. I am sure that in previous threads that most 7's need the top of the upright to go 22mm rearwards to
give the required castor.
Not only does this make the car stable to drive, you get a better feedback through the steering when un-winding out of corners.
