Author: Subject: Omex Speed System, boxed with instructions
steveiow
posted on 3/10/10 at 04:20 PM Reply With Quote
As title.
Excellent device as used on my race car, but now not required.
Easy to install, boxed with all instructions.
Combines a soft cut rev limit with a 10mm ultra bright led shift light.
details here: http://www.omextechnology.co.uk/Revlimiters/Downloads/SYS.PDF
and here: http://www.demon-tweeks.co.uk/Performance/Ignition_System/Shift_Lights_&_Rev_Limiters/OMEX_Speed_System/823/3533
Yours for £70 posted to you.
2012 Locost Race Car #12 - for everything Locost Racing: www.SEWC.co.uk
bob tatt
posted on 3/10/10 at 06:25 PM Reply With Quote
do you know if this will work on a busa im a bit of a div with electrics.
bob tatt
couch22k
posted on 3/10/10 at 06:43 PM Reply With Quote
Hi Steve
Is it the single or twin coil version.
steveiow
posted on 4/10/10 at 07:19 PM Reply With Quote
Not sure how many cylinders as I'm not into bike engines, but it works on all 2, 4, 6 and 8 cylinder engines.
Rev limit is set by the user to a maximum of:
20,000 rpm for 2 and 4 cylinders
12,000 rpm for 6 cylinders
10,000 rpm for 8 cylinders
Shift point is set to whatever you like lower than the rev limit and the soft cut means it starts to limit power just before the rev limit is reached.
Its a great bit of kit with box and instructions.
steveiow
posted on 4/10/10 at 07:20 PM Reply With Quote
Originally posted by couch22k
Hi Steve
Hi Steve,
Its the single coil model.
Thanks!
steveiow
posted on 8/10/10 at 04:29 PM Reply With Quote
Still available!
Rob E
posted on 8/10/10 at 05:04 PM Reply With Quote
Hi steve
would this work on my zetec black top ? (just to be sure) and is it easy to fit ?
Rob
steveiow
posted on 9/10/10 at 12:21 PM Reply With Quote
Hi Rob,
Yes it would work perfectly.
Comes boxed with instructions and very simple to install. About 20 mins and its in and working.
