Author: Subject: Rocker Cover Gaskets
posted on 12/10/10 at 07:37 PM Reply With Quote
Just got my rocker cover back from the powder-coaters... the gasket that came off it looks fine and there was no leak before removal.
Would you change it, or just re-use the old one?
[img][/img]
It's Evolution Baby!
marcjagman
posted on 12/10/10 at 07:42 PM Reply With Quote
Don't be tight, buy a new one.
perksy
posted on 12/10/10 at 07:46 PM Reply With Quote
Buy a New one from Autovaux
Beware the ebay ones, i hd one that lasted a month
Worth doing the SBD camcover mod if you haven't done it already
couch22k
posted on 12/10/10 at 07:47 PM Reply With Quote
Very Nice Very
posted on 12/10/10 at 07:51 PM Reply With Quote
Cheers Perksy... mod done!
Need to get a cambelt kit next... I see there are two choices - old and new. Anyone know what to look for to decide which I have?
posted on 12/10/10 at 08:29 PM Reply With Quote
Got a Payen one at reasonable money... may as well do it right!
perksy
posted on 12/10/10 at 08:53 PM Reply With Quote
The Early ones (pre 93) had 'Round' teeth and the Later ones (post 93) had 'Square' Teeth
Fit a complete Timing belt kit
Check the Water pump whilst your doing the job and replace if required
There's loads of info' on SBD's Website aswell which is well worth a read
[Edited on 12/10/10 by perksy]
posted on 12/10/10 at 09:00 PM Reply With Quote
Thanks again!
BigFaceDave
posted on 12/10/10 at 09:10 PM Reply With Quote
I recently heard of a guy who powder coated his rocker cover and when it was blasted it was grit blasted not bead blasted, The grit impregnated the aluminium and despite washing it until it was completly clean and the water coming out of it was clear when he put it back on started the engine and the rocker cover got warm all the grit fell out and ruined his engine! Not sure if that will effect you or not but I thought it may be worth mentioning!
