femster87
| posted on 25/4/11 at 02:33 PM |
starter motor help
I have just about finished my wiring today. everything works apart from the starter motor, would not even click over. I really dont know what to look
for now. Any pointers would be great.
how do you test starter motor off the loom?
CRAIGR
| posted on 25/4/11 at 02:57 PM |
Have you got a trigger wire from the ignition switch in the cranking position to it to throw the solenoid ?
[Edited on 25/4/11 by CRAIGR]
Davegtst
| posted on 25/4/11 at 03:25 PM |
You need to check you have
1 a permanant live to to solenoid (big thick wire)
2 a feed that goes live from the starter switch (small wire on solenoid)
3 an earth (usually through the starter body bolted to the engine)
4 a working starter motor
femster87
| posted on 25/4/11 at 07:02 PM |
I have checked 1 to 3 but still not crank. I would check if starter motor is working ok
femster87
| posted on 25/4/11 at 07:03 PM |
Yes I have a trigger wire connected
