| posted on 20/4/13 at 01:37 PM |
Start Stop Button?
I see some OEM's have start/stop on the same button.
Is there some magical electronics behind this? or, can it be wired up easily?
dave_424
| posted on 20/4/13 at 01:46 PM |
I know of somewhere that sells a switch that you flick from the off position to ignition on, and then push past that and there is a momentary position
that will crank the engine. So if does everything in one switch but haven't seen a button that will do that.
coyoteboy
| posted on 20/4/13 at 02:22 PM |
Start-stop buttons are digitally controlled generally. There are a few about that do the momentary extra push idea but I've never seen one sold.
Far easier just to use the key!
https://www.fixmystreet.com/
Smoking Frog
| posted on 20/4/13 at 02:49 PM |
Yes I think their would be some electronics behind the switch. But nothing to complicated as the push button would activate a toggle relay I guess.
Quite a few toggle relay examples on the net based around a 555 timer IC with a transistor and a few more components. Just google "Toggle relay
circuit" if your after a locost solution.
Eddie
coyoteboy
| posted on 20/4/13 at 03:48 PM |
You don't want a toggle relay though, you want a button that both arms the ignition AND triggers the starter /until/ the engine has started,
then disengages. Sure you could use a separate toggle for the ignition, then a timed momentary for the start process but you're risking either
not starting or leaving the starter engaged once started. In modern cars they use feedback from the ECU to terminate the starter - this could be done
with some ingenuity bur I think the OP is looking for a plug and play solution.
Smoking Frog
| posted on 20/4/13 at 04:13 PM |
Sorry I thought the question was.
Eddie
mark chandler
| posted on 20/4/13 at 05:30 PM |
Yes there is electronic trickery, we have a BMW with one, you tap the button to start and it will crank until the car fires, tap it to shut off.
It uses the same cleverness for stop/start when waiting at traffic lights etc.
morcus
| posted on 20/4/13 at 05:32 PM |
The one in the ford my dad rented was the same, gives instructions to a computor and was apparantly a pain in the arse as the car stalled easilly.
| posted on 20/4/13 at 08:26 PM |
Apart from anything thing else you need an obvious indication which position the ignition switch is in that doesn’t depend on an electrical
supply, yes it could be done with a bit of electromagic (for example a PIC circuit) but life is too short. Push buttons are fine for starters but
best to avoid push buttons or even push pull switches for the ignition.
Keep it Simple and keep to accepted conventions with safety critical controls.
Simon
| posted on 20/4/13 at 10:19 PM |
My Espace has keyless entry so you walk up to car, sensor detacts keycard, IR detector behind handle sensors bodyheat from hand and unlocks car, pull
handle and get in. Push start/stop button, engine starts, stick it in gear and let out clutch and it releases handbrake. When done push button, turns
off engine and applies handbrake. Get out of car and walk away as car locks itself.
It's brilliant if you're a lazy git like me and I'd hate to think how complicated it gets "behind the scenes"
Simon
coyoteboy
| posted on 21/4/13 at 11:13 AM |
Sorry I thought the question was. Is there some magical electronics behind this? Eddie
It was, but you proceeded to explain what it might be (but isn't), so I was just pointing out it's even more complicated than you
explained and that wouldn't work if the OP wanted to do it
[Edited on 21/4/13 by coyoteboy]
Smoking Frog
| posted on 21/4/13 at 02:02 PM |
More information on "Relay Toggle Circuit" can be found here http://www.bowdenshobbycircuits.info/page9.htm
If you used the "Relay Toggle Circuit Using a 555 Timer" to control the ignition circuit and a delayed timer to activate the starter that
just leaves switching off the ignition circuit without activating the starter. Admittedly I haven't figured the last bit out.
Eddie
scudderfish
| posted on 21/4/13 at 06:20 PM |
Eddie
I'm sure you could do something with the alt tell tale feed. If the current is flowing, power the starter, if it isn't kill the ignition.
